Old 01-22-2024, 03:34 PM
er455 er455 is offline
Default Aluminium drive shaft
Hey guys does anyone know if a 3.5 aluminium driveshaft will fit my 1979 trans am with a Tremec magnum transmission ?? Just want to make sure it will in my trans tunnel Thanks
Old 01-22-2024, 05:05 PM
Yep they fit
https://youtu.be/XqEydRRRwqE
Old 01-22-2024, 05:16 PM
Default Drive shaft
Yep they fit
Do you like it ? Does it factor in if the car is lowered ?
Old 01-23-2024, 06:48 AM
I've never used them in a lowered car but don't foresee an issue there really. I guess it depends on your definition of lowered.
I do like them for the most part. The only drawback pertains to your question. They are larger than a typical steel or chrome molly piece because they have to be to reach certain strength requirements.
I'm having one made for a Vega which has the smallest tunnel in the world lol. But it will fit fine. The stock shaft is 2.750" diameter and the aluminum is only 3.5" diameter. Not a big increase really. That's only 5/8" per side.
Old 01-23-2024, 07:06 AM
I've never used them in a lowered car but don't foresee an issue there really. I guess it depends on your definition over lowered.
Thank you for the help
