Old 02-11-2024, 05:02 AM
Kenth's Avatar
Kenth Kenth is online now
Short Baldwin B39 is the same as Hastings LF222.
Tall Baldwin B9 is the same as Hastings LF212.
Hastings are available at Rockauto.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-11-2024, 08:38 AM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
Thumbs up on Fleet Filter, have been using them for over 20 years.
Another option that should be around for quite sometime, the Application Listings go as far as 2012 for GM, is the Wix 51522. (https://www.wixfilters.com/Lookup/Pa...spx?Part=78145)
Nearly the same specs as 51045, only slightly shorter and a lower burst pressure. (if you reach the burst psi.... you have other issues)
I use this filter on the GTO and my truck. 1 PN serves 2 applications.
1966 GTO Resto-Mod. 2nd owner California car, Factory Air, Power Windows, Kauffman Heads, March Serpentine, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R Level 3, Yank 2400 Stall Converter, Dutchman Axles, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust, Continental ExtremeContact Sport 02
Old 02-11-2024, 08:53 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Are there any issues using the Baldwin B39 or the Hastings filter with a stock bypass in the filter housing?
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 02-11-2024, 09:27 AM
Cliff R's Avatar
Cliff R Cliff R is offline
The Baldwin and Hastings filters are still USA made and excellent quality. Pretty much everyone else has sold out to Tiawan or China, and the quality it showing it.
I had been useing AC Delco on all my other vehicles until the last batch I ordered for my Nissa Xterra showed up with a plastic basket to hold the filter element in place and the shell was obviously thinning and crushed easily. JUNK!
I used a cross reference and found Baldwin filters to replace them. Now using Baldwin or Hastings on all my vehicles, and power equipment and they are top quality parts.......
Old 02-11-2024, 10:00 AM
i82much's Avatar
i82much i82much is offline
I like the K&N HP2006. Way too expensive but that nut on the bottom makes it a lot easier to get on and off around the headers on my 65 GTO.
Old 02-11-2024, 10:04 AM
mgarblik mgarblik is offline
We cut oil filters open to inspect the elements after break-in on the engine dyno. I have noticed a couple things about WIX/NAPA filters since they were bought out a couple years ago. 1. The cans are thinner than the older ones. They cut through much more easily than the older ones and are surprisingly thin. 2. Many of the WIX/NAPA filters are just slightly shorter, and smaller diameter than ones from 1-2 years ago with the same part number. You can see it visually and my cup style filter wrenches will not grab and hold the new filters as well as the older ones. Much like many food items that are shrinking in the grocery, the filters are shrinking very slightly and I assume to save a penny or two on each one. Still like the filters but they are cutting corners in ways only the careful consumer would ever notice. FWIW.
Old 02-11-2024, 10:11 AM
Steve C. Steve C. is offline
Both Baldwin filters and WIX filters are part of a diversified group of manufacturing companies.
Both with filter products in the world market and with manufacturing and distribution centers in the United States, and worldwide.
Including China.
I would suspect other companies that offer oil filters might be in the same situation.
And not just oil filters, one might question where any automotive products are manufactured.
Old information here:
Old 02-11-2024, 10:28 AM
track73 track73 is offline
Originally Posted by Mr_GTO View Post
Currently unavailable
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 02-11-2024, 12:47 PM
Wix Filter's new factory
https://youtu.be/jiKbyi9fEmE?si=TLkULjxvT8IfyAQg
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
The Following User Says Thank You to Singleton For This Useful Post:
Old 02-11-2024, 12:59 PM
Including China.
Yeah a lot of that stuff has moved over seas, including Baldwin. They now have facilities in Europe, Mexico, Australia, China, South Africa and Morocco according to a site search.
I suspect that's pretty common with most any filter these days, or anything else you buy, lol.
https://youtu.be/XqEydRRRwqE
Old 02-11-2024, 01:20 PM
gtorich gtorich is offline
Just doubling checking here, if talking about the small balwin filters..........the B39 is 3 11/16 OD and doesnt fit on my 66 with dougs headers, but the B30 is OD 3 and length iis 5 1/8............that one seems to fit my car.
Rich
Rich
Old 02-11-2024, 04:51 PM
Kenth's Avatar
Which WIX 51258 is prefered, black or white?
https://www.rockauto.com/en/moreinfo...t=5340&jsn=273
https://www.amazon.com/Wix-51258-Spi...A1UT4CS4MVANP0
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-11-2024, 05:44 PM
64speed's Avatar
64speed 64speed is offline
Rich
Fits my 64 with round port Doug’s headers just fine.
Old 02-11-2024, 05:50 PM
Originally Posted by Kenth View Post
Either is fine Kenth. I've cut both of them apart on a regular basis and they are exactly the same internally. The Napa Gold used is the black version, all Napa does is remove the 5 from the part number and sell it as a 1258. It's the Wix filter as well.
Old 02-11-2024, 05:55 PM
Is there a problem with using an AC Delco PF61 on a car that isn’t raced and driven sparingly?
flat pistons
RPM rods
w 2.73 rear gear
Old 02-11-2024, 06:16 PM
I've never liked the ac delco filters. Even way back in the 90's I felt they were poor quality when I was cutting them apart, typically finding a loose filter inside due to the retaining device they used shrinking. Can't remember for sure now if it was a piece of rubber but that's what comes to mind. I want to say something with a piece of cardboard, lol But it's been so long since I've cut one of those open my memory is fuzzy, I've just never been interested in revisiting those things.
  #38
Old 02-12-2024, 10:31 AM
Skidmark's Avatar
Skidmark Skidmark is offline
Originally Posted by 65 Lamnas View Post
I just ordered 6 from Rock Auto with my discount code...4.81 each. Rock Auto Discount code is good til March. 257708170227572024
Same here. I got 6 @ 4.81 w/o code (forgot to enter it) 40.41 delivered.
  #39
Old 02-12-2024, 03:10 PM
Verdoro 68's Avatar
Has anyone confirmed that the Wix is actually discontinued? Summit seems to be the only place that no longer has it, but it looks to be readily available everywhere else. The Wix site doesn't list it as discontinued either.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #40
Old 02-12-2024, 03:46 PM
ANDYA ANDYA is offline
Did some research. Some other sights say the WIX is discontinued yet many suppliers still show them in stock. Country of origin is now showing China. Better off following Cliff’s advice and look for Baldwin/Hastings from now on. Years ago I purchased four dozen WIX 51049 long filters when they were US made. Still working through them. Also have 18 AC PF24 filters in stock.
