Old 03-16-2024, 12:17 PM
Joe37 Joe37 is offline
Default Vacuum verse mechanical
Does any one have any documentation on what cars got the vacuum systems and what got the mechanical systems? I have seen original big cars with manual transmissions and vacuum tri-power. Never really paid any attention to GTO's with automatics but don't recall seeing any vacuum systems on the GTO's.
Old 03-16-2024, 07:49 PM
65 Lamnas's Avatar
IIRC, Pontiacs never used the vacuum operated on M/T cars after 1964....only the A/T cars in 65-66.
Old 03-17-2024, 09:55 AM
Thats kind of what I figuring, my cousin has an untouched '64 GrandPrix with manual transmission and vacuum tri-power setting in his stash of cars.
So, all the mechanical sets prior to 1965 were dealer add-ons or aftermarket?
1965 and 1966 are the only sets with factory mechanical linkage?
What about a 1964 GTO with automatic?
Old 03-17-2024, 10:28 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 3x2 linkage
The following are for the GTO series from the Factory.
1964 Tri-Power,
Manual shift and Automatic came with Vacuum linkage.
1965 Tri-Power,
Manual shift - Mechanical linkage. 19091 built.
Automatic - Vacuum linkage. 1456 built.
1966 Tri-Power,
Manual shift - Mechanical linkage. 15803 built.
Automatic - Vacuum linkage. 1759 built.
Old 03-18-2024, 08:18 PM
Thanks for the information on the GTO's. Could one assume the '65-6 big cars were the same way?
Not that any of this matters really, just curious.
Joe
The Following User Says Thank You to Joe37 For This Useful Post:
Old 03-18-2024, 08:20 PM
Stuart's Avatar
Stuart Stuart is offline
1961 big cars with tripower were all vacuum operated from the factory, but a mechanical linkage was available over the counter.
Old 03-18-2024, 10:59 PM
60sstuff's Avatar
Default Big car vacuum
Beautiful ‘66 Reef Turquoise 2+2 421 HO Survivor with it’s full vacuum linkage intact.
ID:	630596   Click image for larger version
ID:	630597   Click image for larger version
ID:	630598   Click image for larger version
ID:	630599   Click image for larger version
Old 03-21-2024, 01:08 PM
Lets go with this,
1964 and older, all vacuum operated, manual or automatic transmissions
GTO, and big car
1965 - 1966, automatic transmissions , vacuum operated tripower
1965 - 1966, manual transmission, mechanical tripower
Mechanic linkage was available over the counter prior to 1965
Aftermarket kits also available
Old 03-21-2024, 10:51 PM
60sstuff's Avatar
Lets go with this,
GTO, and big car
That looks correct.
Old 03-21-2024, 11:59 PM
60sstuff's Avatar
Default Auto / 3x2
Joe,
Kickdown switch for Automatic transmission with Tri-Power.
BIG CAR, 65-66 had the switch located “under the hood”.
A bracket on the LH side of center carburetor held the automatic kickdown switch.
GTO, 1965 also had the switch located as above “under the hood” on LH side of center carb.
GTO, 1966 now had this transmission kickdown switch located “inside” above the accelerator pedal.
A few on this site haven’t figured this out yet.
ID:	630831   Click image for larger version
ID:	630832   Click image for larger version
ID:	630833   Click image for larger version
ID:	630834   Click image for larger version
Old 03-22-2024, 08:55 AM
Rich-Tripower's Avatar
What's the best thing about the vacuum actuated tripower system? You can remove all the vacuum stuff and replace it with a simple mechanical system! Even the most beautifully restored vacuum system looks better sitting in a box on a shelf than on a car in my opinion. We have all the parts to the vacuum system for our 64 GTO but it has never been on the car in my memory. The temp switch is seized anyway. Even Pontiac sold mechanical replacements through the parts department back in the day. Why they ever had a vacuum system in the first place is beyond me.
Old 03-22-2024, 09:43 AM
bill ryder's Avatar
bill ryder bill ryder is offline
Those are great pictures, Chris!!!
"Bill"!
The Following User Says Thank You to bill ryder For This Useful Post:
Old 03-22-2024, 09:59 AM
60sstuff's Avatar
Originally Posted by Rich-Tripower View Post
What's the best thing about the vacuum actuated tripower system? You can remove all the vacuum stuff and replace it with a simple mechanical system! Even the most beautifully restored vacuum system looks better sitting in a box on a shelf than on a car in my opinion. Why they ever had a vacuum system in the first place is beyond me.
Opinions vary.
Some people like repainted cars with over the counter incorrect items.
These cars are “a-dime-a-dozen” at cars shows.
Me, and many others prefer the Original Factory Built cars that are few.
Old 03-22-2024, 10:00 PM
Our car is hardly a painted-the-wrong-color modified car. But that vacuum system does not benefit the car.
