Old 05-05-2020, 09:50 PM
OG68 OG68 is offline
Usually on the bottom. Heres a picture of the one I have currently. C12 8
Should have a CT stamp on top at the front.
ID:	539260   Click image for larger version
Old 05-05-2020, 11:19 PM
68pongto's Avatar
68pongto 68pongto is offline
Here are some pictures of a couple of 5452310 master cylinders. The first two are of my RA II car with a date of E 1 8 or E 7 8. It has cracked due to freezing so it is no good. I also have a picture of another one with no date.
ID:	539287Click image for larger version
ID:	539288Click image for larger version
Old 05-06-2020, 12:05 AM
68pongto's Avatar
Here are a couple of pictures of the 5460465 power drum brake master cylinder with the bleeders.
ID:	539302Click image for larger version
Old 05-06-2020, 12:55 AM
dataway's Avatar
dataway dataway is online now
What application brake system is this MC for? And what is the extra valve there for? Disk brakes?
Old 05-06-2020, 09:02 AM
68bird400HO's Avatar
Power disc
The Following User Says Thank You to 68bird400HO For This Useful Post:
Old 05-06-2020, 07:35 PM
tinindian68's Avatar
tinindian68 tinindian68 is offline
Here’s what I found:
Number: 5452310
The number here is 158.
If there was a code here, I can’t read it.
Don’t know if this is of any use to anyone. It worked when removed, but probably should be rebuilt.
Old 05-07-2020, 02:55 PM
Thanks for the photos. However the date is to late and won't work for me.
Old 06-06-2023, 09:36 PM
compsur's Avatar
compsur compsur is offline
I recently pulled a 0465 MC from my full size Bonn with Power Brakes, it was original to the car. Could this be right, did they install 0465 in both FS and T series?
1967 Bonneville Sport Coupe (Plum Mist), Org. paint, Org. 38K miles
1967 Bonneville Convertible (Montego Cream, Cal Car, 105K miles
1967 Executive Wagon (Plum Mist), Org. paint, Org 35K miles
1981 Bonneville Brougham Coupe (Black) Moonroof, Org. 11K miles
Old 03-23-2024, 07:15 PM
etennett etennett is offline
Default 68 Master Cylinder casting number
Well, look what I found in my parts collection .... if not for the virus lockdown I would have probably never taken the time to look so thoroughly for it and bought another one somewhere.
Looks like I might have already rebuilt it some decades ago, has original Delco cover and seal too. Found various other things I need also.
Chucked the other one in the recycle bin already
Hi. I know this thread goes back a few years. But do you still have the MC for the 68 gto/lemans? Casting # 5460465?
eric
Old 03-24-2024, 05:38 AM
dataway's Avatar
I PM'ed you. Unfortunately that unit is now on my GTO on I don't have any others.
Hope you find what you need.
Old 03-24-2024, 06:30 AM
eric
Old 09-21-2025, 06:14 PM
compsur's Avatar
Eric let me check i may still have that 0465 MC unit in the garage....PM me if you are still interested.
