Old 04-09-2024, 08:32 AM
ejgoat ejgoat is offline
Default Gto splash shields
I need a pair of 1964 gto front splash shields, anybody have a set for sale, non air
Old 04-10-2024, 07:23 AM
Andre's Avatar
Andre Andre is offline
I definitely have one, but might have a pair. I thought they all had the holes for the a/c baffling even if not used for ac. You can email me at [email protected]
Old 04-10-2024, 08:08 AM
chrisp chrisp is offline
Have a set of 2 for the fender to core area PM sent
Old 04-10-2024, 10:24 PM
Rich-Tripower's Avatar
Just out of curiosity, can someone provide pictures on the car? I can't picture what is being discussed.
TIA
The Following User Says Thank You to Rich-Tripower For This Useful Post:
Old 04-11-2024, 07:16 AM
TIA
https://www.ebay.com/itm/11602668366...602823cae239ff
Old 04-11-2024, 10:10 AM
GtoFM's Avatar
GtoFM GtoFM is offline
Splash shield pics.
ID:	631904   Click image for larger version
The Following User Says Thank You to GtoFM For This Useful Post:
Old 04-12-2024, 07:19 AM
Originally Posted by chrisp View Post
Not mine just for reference, set i have for sale in great condition.
Old 04-18-2024, 07:31 AM
64 gto front splash shields avail & A/C long lowers
Old 04-18-2024, 11:53 AM
GtoFM's Avatar
Is the shield different if the car has A/C or is something added?
Old 04-18-2024, 06:00 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
Can’t answer your question directly, however my 69 MPC shows two different shields for the 64.
One for the T/6-T/8 with AC and TI. I’m guessing TI is transistor ignition which need to be shielded?
The other is for T/6-T8 except TI- makes no mention of AC.
My 74 MPC shows no listing so discontinued by that time.
The pictures are the splash shields from my 64 GTO- NON-AIR. The car was all original when I purchased it in 69 so I know these are correct for non-air application.
ID:	632282   Click image for larger version
The Following User Says Thank You to 64-3Deuces For This Useful Post:
Old 04-18-2024, 06:33 PM
Here are a pair of 1964 slash shields. One has a factory A/C sheet metal baffle installed on the bottom, clearly both A/C and non-A/C applications used the same splash shield.
The 1964 A/C baffle has a narrow extension that wasn’t used for 1965 as you can see in the last 2 photos (‘65 baffle at the bottom). The drivers side 1964 baffle is an original, the passenger side baffle was fabricated for me by my brother, they’re not easy to come by.
Right now in the process of restoring the factory A/C on my Le Mans convertible.
ID:	632288   Click image for larger version
ID:	632289   Click image for larger version
ID:	632290   Click image for larger version
ID:	632291   Click image for larger version
Old 04-18-2024, 06:50 PM
64-3Deuces's Avatar
b-man,
Good info, the difference for the AC being the added shield; never seen one.
Do you have any idea why the MPC shows used also on TI as noted in my post #10????
Old 04-18-2024, 07:45 PM
I have no idea in the TI ignition.
Just sharing some parts I’ve accumulated for my long-term project.
Old 04-18-2024, 11:07 PM
GtoFM's Avatar
Thanks again b-man! So the staples on the added baffle are for the A/C seal kit filler piece?
Old 04-18-2024, 11:56 PM
Indeed they are.
Old 04-19-2024, 10:10 AM
TI had a cutout for the cover - amplifier box.
