Old 05-05-2024, 05:01 PM
65 Lamnas's Avatar
Installed new brake lines, bled the brakes. Happy that the Chevelle brake lines fit no problem with a little modification of the brake line bracket. Put the car back on the ground and got the pinion angle in the ballpark by adjusting the upper control arms. Just waiting on the new driveshaft and I should be ready to roll.
Very nice. I had a similar rear setup on the '67 Lamnas. Is that a .875" or 1.000" rear bar?
  #482
Old 05-05-2024, 06:13 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Well it started after the winter slumber, and went to a car show!
The Following User Says Thank You to gtokid1968 For This Useful Post:
  #483
Old 05-05-2024, 07:16 PM
67drake's Avatar
67drake 67drake is online now
Drove the ‘63 LeMans to the gas station to get gas for my Mercury, as I had just drained the 5 year old gas out of it.
‘55 Catalina
  #484
Old 05-05-2024, 07:24 PM
Thumbs up
Going to wash it, insure it, register it and start driving it again.
Might even go crazy and buy a car cover for it, it’s a garage queen that never sits outside.
ID:	633284   Click image for larger version
The Following 2 Users Say Thank You to b-man For This Useful Post:
  #485
Old 05-05-2024, 10:43 PM
Verdoro 68's Avatar
It’s a .875 I got from GM years ago. I thought about upgrading to a 1” since I have a big sway bar on the front but it’ll have to wait until my bank account recovers from this swap.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #486
Old 05-06-2024, 12:54 AM
Thumbs up
Drove my ‘64 Le Mans convertible with its new 421 HO out on the road for the first time in over a decade.
Still needs plenty of work but it’s running, stopping, all the lights are working along with the power windows and the convertible top is operational for the first time since I bought this Le Mans in 1997.
I’m pretty stoked.
So I drove 2 Pontiac convertibles today, 22 and 60 years old.
ID:	633301   Click image for larger version
ID:	633303   Click image for larger version
ID:	633304   Click image for larger version
ID:	633305   Click image for larger version
The Following 5 Users Say Thank You to b-man For This Useful Post:
  #487
Old 05-07-2024, 12:40 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Very unique car... a 1954 LeMans!
  #488
Old 05-07-2024, 01:10 AM
Cool
I fixed my typo. I need better reading glasses it seems.
Anyway I put most of the interior back together until my Legendary upholstery in the original Saddle color arrives hopefully at the end of this year. I plan on driving it this summer and finishing up the air conditioning and heater assembly when the seal kit that’s currently on back order arrives.
The original seat belts cleaned up nicely after a long soak in some Woolite and later some Simple Green and several rounds of scrubbing. Cleaning them up was quite the process as they were filthy.
All of the interior courtesy lamps are working including the console compartment lamp so it’s all coming together nicely.
ID:	633354   Click image for larger version
ID:	633355   Click image for larger version
ID:	633356   Click image for larger version
ID:	633357   Click image for larger version
  #489
Old 05-07-2024, 07:31 AM
I would not - the rear bar design is problematic to begin with - a heavier bar makes it worse.
  #490
Old 05-08-2024, 04:45 PM
65 Lamnas's Avatar
Bought a brand new Holley Street Dominator....the downside was the guy wouldn't ship and I had to drive 3 hrs one way to get it.
  #491
Old 05-09-2024, 12:26 AM
Shiny Shiny is online now
Started an attempt to straighten the front valance our movers mangled.
As-mangled:
Stopping point for the day:
ID:	633437   Click image for larger version
The Following 4 Users Say Thank You to Shiny For This Useful Post:
  #492
Old 05-09-2024, 03:35 PM
carcrazy carcrazy is offline
Purchasing parts for the 62 Pontiac engine build.
The Following User Says Thank You to carcrazy For This Useful Post:
  #493
Old 05-09-2024, 04:00 PM
Cool
Took both convertibles out for a spin last night.
Actually only intended on driving the ‘64 but had an issue with the brakes dragging so I let them cool off at a local park about 3-1/2 miles from my home. I’m suspecting I adjusted the pedal pushrod a bit too tight so I’m going to rectify that today.
After about a half hour I went back home and grabbed the ‘02 WS6 Trans Am to meet up a group of my VW friends. I’m parked next to my friend who owns a ‘71 Squareback with a ‘99 Corvette LS1 swapped in.
Beautiful spring evening where everyone hung out in T-shirts, by 10pm when I left it was only in the mid-60s.
ID:	633462   Click image for larger version
ID:	633463   Click image for larger version
ID:	633464   Click image for larger version
ID:	633465   Click image for larger version
  #494
Old 05-09-2024, 04:11 PM
65 Lamnas's Avatar
Painted it.
The Following User Says Thank You to 65 Lamnas For This Useful Post:
  #495
Old 05-10-2024, 08:27 PM
SD455DJ SD455DJ is offline
I drove the ’70 Tempest to the F.A.S.T. Race at Martin US-131 Motorsports Park today 65 miles there, raced it, then drive back home. The last time I drove to a track and raced a car (my ’70 RAIV Judge), then drove back was in 1985 at the 1st Supercar Showdown at Beechbend Raceway near Bowling Green, Kentucky (1000 miles round trip). Dan trailered his ’71 401 Javelin but, unfortunately, it was plagued with Autolite 4100 carb gremlins (it typically runs in the 12.80 @ 106 mph range). The weather was cool (63) and dry, but with a headwind out of the north of 5 – 15 mph. This was a last minute decision to go, so we promptly forgot our carb kits with all the secondary metering rods & jets, spark plugs, and the corresponding 13/16” socket (could of sworn it was in there…!). So, the spark plugs (AC-R45S) that were in it for the dyno session back in 2019 stayed in it. I didn’t even touch the timing, but did check it…38 degrees, dwell was fine. The DA was around 1300’ despite the cool temps.
We were just there for the day and the Tempest ran a best of 13.15 at 102.79 mph into a 15 mph headwind. Ran a 13.20 earlier. It only turns 4800 rpm through the traps with the 3.42 gears. It really needs some 3.73’s or 3.90’s. The TH400 upshifts automatically at 5600 rpm.
Dennis
ID:	633530   Click image for larger version
ID:	633531   Click image for larger version
The Following 4 Users Say Thank You to SD455DJ For This Useful Post:
  #496
Old 05-10-2024, 08:37 PM
vertigto's Avatar
vertigto vertigto is offline
VERY nice Tempest.
  #497
Old 05-10-2024, 09:36 PM
Verdoro 68's Avatar
Installed the new driveshaft which is the last piece of the puzzle for my rear diff swap project. Took more time and more money than expected, but don't most car projects? Ran in the new gears on jack stands as per the break in instructions and no alarm bells went off. I'll get it out on the road tomorrow and see if I need to adjust the pinion angle any more.
ID:	633536   Click image for larger version
ID:	633537   Click image for larger version
ID:	633538   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
  #498
Old 05-10-2024, 10:11 PM
tom s tom s is offline
Sold my 69 Firebird TA clone!Except no Trans Am on the car anywhere.Tom
  #499
Old 05-11-2024, 02:42 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is online now
Tom, why did you sell it and was this a RAV engine?
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #500
Old 05-11-2024, 03:43 PM
Going to AZ,455 D port.Tom
