Old 06-29-2024, 11:25 PM
67drake's Avatar
67drake 67drake is offline
On my Pontiac nothing, but it’s a means to an end…..
I rebuilt the engine on my ‘62 Mercury over the winter. I had about 75 miles on the break in and lost 2nd gear on the transmission. Well, that was 6 weeks ago. I finally got out in the shop and pulled the tail shaft to get the governor out. Cleaned it up and reinstalled the tail shaft, then dropped the pan , cleaned the brass screen/filter, then filled it up. I still had it up on jack stands and it shifted in 2nd gear. I’ll try to actually road test tomorrow.
OK, now I can swap spots in the garage and pull the engine out of the LeMans. Massive oil leaks, detonation , and who knows what I’ll find when I tear it down. Hoping for an overhaul and cam swap, but may rebuild depending on what I find.
I just wanted to get the Mercury running before I tore into my next project.
‘55 Catalina
  #682
Old 06-30-2024, 10:52 AM
carcrazy carcrazy is offline
Cleaning out the garage so I can get to it!............
The Following User Says Thank You to carcrazy For This Useful Post:
  #683
Old 06-30-2024, 06:20 PM
67drake's Avatar
Had to go into,and past, Madison today for a celebration of life for my wife’s aunt who passed last year.
It was a sunny day with a cool north breeze. I checked the weather and it was 68 and barometer was at 30.3. Great day to take a Pontiac! We took the GTO and put 144 miles on it.
Now to get that Mercury out and the LeMans into the project garage stall.
‘55 Catalina
The Following 4 Users Say Thank You to 67drake For This Useful Post:
  #684
Old 06-30-2024, 08:29 PM
67drake's Avatar
Mercury shifted great. Drove it about 25 miles.
So swapped the cars around and put the LeMans on dollys and positioned it in the spot of no return. I doubt I’ll drive it again before I pull the engine, so it will probably be there till spring. Hopefully with a new cam and an engine that doesn’t pee fluids.
‘55 Catalina
  #685
Old 06-30-2024, 08:42 PM
cdrookie cdrookie is offline
Washed the undercarriage to get the 2.5yrs of body shop dust off.
The Following 2 Users Say Thank You to cdrookie For This Useful Post:
  #686
Old 07-02-2024, 03:57 PM
jhein's Avatar
jhein jhein is offline
Went for a drive today. Beautiful day for it.
Ordered a pair of MT ET Street S/S tires for the rear. 255/60-15. BFGs are too slippery. I was considering the 275s but then I'd probably need a 8" wheel. I'll try these first. If it's not enough then I guess I can put the 255s on the front and get 275s for the rear.
The Following 2 Users Say Thank You to jhein For This Useful Post:
  #687
Old 07-02-2024, 05:59 PM
Radman's Avatar
Radman Radman is offline
Picked the car up from the glass shop. New windshield.
Name:	New Windshield.jpg
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
The Following 3 Users Say Thank You to Radman For This Useful Post:
  #688
Old 07-02-2024, 06:11 PM
Polished the grills on my 67 GTO.
The Following 2 Users Say Thank You to carcrazy For This Useful Post:
  #689
Old 07-02-2024, 08:35 PM
RocktimusPryme's Avatar
Took the 67 to play a round of golf. Had a panic attack when it wouldn't start when I tried to leave. Could hear the solenoid clicking, but no spin. Finally after about 15 tries it spun over and started. Maybe time for a new mini starter. Its been in there for like 7 years, so I cant be overly mad if it is going out.
Started just fine when I got home.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
  #690
Old 07-02-2024, 09:54 PM
4dblnkldude's Avatar
I vacuumed out the 81 and put new floor mats in. I had them embroidered from Ames.
The Following User Says Thank You to 4dblnkldude For This Useful Post:
  #691
Old 07-03-2024, 11:51 AM
BILL BOWMAN1's Avatar
Catalina :
New Addco sway bar installed on front.
New rear sway bar arrived, install soon
GTO : 2 friends from work helping install rear bumper later today.
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #692
Old 07-03-2024, 02:13 PM
jhein's Avatar
Yesterday I made a new set of plug wires. I made the set that was on there over 2 years ago when I still had the RAIII. After going through the motor swap, they got pulled off and on countless times. When I did my compression test a couple weeks ago, two of the terminals pulled off the wires when I pulled them off the plugs. So I suspected the others may not be far behind. When I made that set I think I crimped too close to the end of the insulation which made them more prone to coming off.
Anyway, recent driving was just feeling a little off, like maybe a little rougher than normal. So when I pulled the wires to replace them, the #5 boot/wire came off the plug and left the terminal on the plug. Before I pulled it off I could see that it didn't look right. I'm using 180* boots and that boot wasn't quite straight and I could wiggle it so I knew something was wrong.
Driving this morning with the new wires it felt very different. Much smoother and better power.
So I think that the #5 wire was just barely making contact with the terminal, maybe even intermittent contact giving me a miss. Anyway, noticeable difference after the change, much better.
The Following User Says Thank You to jhein For This Useful Post:
  #693
Old 07-03-2024, 03:12 PM
Now the fun starts, twisting, turning, shimming this and that to get gaps even.
  #694
Old 07-03-2024, 07:33 PM
67drake's Avatar
Nothing. I left them at home and went to the town cruise in in my Mercury. Gotta get miles on this thing and get that break in oil out.
Town of 537 people,and we had a little over 100 cars here.
ID:	636277   Click image for larger version
ID:	636278   Click image for larger version
ID:	636279   Click image for larger version
‘55 Catalina
  #695
Old 07-03-2024, 07:37 PM
67drake's Avatar
Try again!
ID:	636281   Click image for larger version
ID:	636282   Click image for larger version
ID:	636283   Click image for larger version
‘55 Catalina
The Following 2 Users Say Thank You to 67drake For This Useful Post:
  #696
Old 07-03-2024, 11:40 PM
Steve Shively Steve Shively is offline
Getting the Firebird back together between moving from old garage to new one.
The Following User Says Thank You to Steve Shively For This Useful Post:
  #697
Old 07-04-2024, 09:40 AM
RAIIIJudge's Avatar
RAIIIJudge RAIIIJudge is online now
what did I do ? what haven't I done probably better. got a long "to do" list here ...
riv-nutted one sway bar bracket-threads other day .. quite a difference when going down the road now.
best I can tell car's alternator's never been apart and bearings were loud. ordered some bearings then figured I might as well rebuild it while I was in there so I ordered a kit w/ improved stator (this is a 37 amp alt) .. while waiting nearly a month for shipping I read fine print that in order to get full effect of new stator you should replace rotor ... ok so I call to order a new rotor to be informed I have to order online "we dont take orders over the phone" ... hm ok but can rotor please be shipped along with kit and bearings? honestly sounding surprised at the Q "oh no we cant do that .. its no biggie just pull alternator out and replace rotor when new one arrives". I passed on new rotor.
stuff arrives and I open alternator which was just filthy inside w/ front bearing completely trashed. I'd never rebuilt one before but it wasn't difficult: after cleaning had to press diodes and bearings out and install new plus other stuff. when I had it back on car I quickly grazed positive terminal to battery and sure enough something arced inside case. got it apart and found that a diode lead was lying against housing. once I addressed that and got back on car I was all set.
its nice hearing only the motor and not bad bearings.
The Following 2 Users Say Thank You to RAIIIJudge For This Useful Post:
  #698
Old 07-04-2024, 10:14 AM
jamesq's Avatar
jamesq jamesq is offline
I took my 63 Safari out for about a 20 mile drive early this 4th of July morning.
That's about all I can do, it's brutally hot right now!
James Q
James Quayhagen
The Following 2 Users Say Thank You to jamesq For This Useful Post:
  #699
Old 07-05-2024, 11:28 AM
NOTHING. Already 88* and 73% humidity. Inside stuff only today. I’m going to enjoy a rare day off.
  #700
Old 07-05-2024, 09:15 PM
67drake's Avatar
What’s the saying about a long journey starting with the first step, or something.
Pulled the hood off of the ‘63 tonight. I’m going to start pulling the engine as I have time. Everyone is gone this weekend except for me, so figured I might have time in the garage. I wanted to get the hood pulled while my 12 year old is still home, so he could help. He’s literally about 1/3 of the size of my 16 year old, who is gone working in a repair shop for the summer. He’s the one usually helping me. I told my 12 year old I don’t want a busted windshield, and he handled it fine.
‘55 Catalina
