Old 10-10-2023, 04:11 PM
Canadian speedos were MPH in those days...fyi
Nice car but only for the rich...good luck
Old 10-20-2023, 06:22 PM
OldSDGuy OldSDGuy is offline
Default Ebay '73 SD
KAINSEL, Block appears correct but it's not numbers matching for all components across the board. Carb not correct. Carb float bowl assembly is for an auto '74 SD. Carb air horn assembly doesn't have the correct slanted vent. Secondary valves in the air horn assembly aren't correct. Distributor isn't correct. No idea on the transmission as there are no pics that I saw. Late production '73 SD....a rare car for sure.
  #5643
Old 10-21-2023, 11:40 AM
starlightblack's Avatar
starlightblack starlightblack is offline
eBay 2019. As this is a Canadian export car there is a very good chance it was once a victim of significant rust. Needs a closer look for sure.
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
The Following User Says Thank You to starlightblack For This Useful Post:
  #5644
Old 12-22-2023, 10:10 AM
Canadian export 2V87X3N145319 is back again, now on the docket at BJ in January...
Name:	Screenshot 2023-12-22 at 9.00.29 AM.jpg
  #5645
Old 01-20-2024, 11:56 AM
Brewster's Avatar
Brewster Brewster is offline
Great, color combo!
  #5646
Old 01-28-2024, 01:40 AM
KAINSEL KAINSEL is offline
Sold $159,500. Quite a bit higher than 2019 listing
  #5647
Old 02-27-2024, 10:24 PM
SD73's Avatar
SD73 SD73 is offline
Does anyone know if the rear driver side valve cover bolt closest to the intake manifold has a clip attached to it? If it does is the clip hole for it on the right or left of the bolt? Were there 3 clips per side?
SD73
  #5648
Old 04-11-2024, 01:50 PM
SD73
Not sure if this applies to yours since you're asking specifically about a '73 but on my '74 SD (mostly original), which I'm assuming would be similar there is no plastic push pin clip in that metal bracket hole which btw is on the left side (toward front of car) of the valve cover bolt. (see pic) The frontmost metal bracket hole on that side has a metal clip that holds the taped electrical wire bundle. Interestingly, there is a metal bracket beneath each of the 8 valve cover bolts. A plastic push pin clip is only on the front left bracket (temp sensor wire) and on the rear passenger side bracket (TCS wire). It's very possible that most of the other metal brackets had a plastic push pin clip for some of the emissions related hoses and perhaps a spark plug wire holder but they were not on my car when I purchased it from the original owner back in '77. Hope that helps somewhat.
  #5649
Old 04-27-2024, 06:16 AM
SD73's Avatar
Thank you for the reply, OldSDGuy. The '73s were actually a little different from what I've been able to tell. It looks like '73s got 5 clips total.
That's a nice engine bay!
  #5650
Old 05-07-2024, 05:29 AM
bluebird455 bluebird455 is offline
Default SD cam value
What would you guys say an NOS cam is worth.
just wondering, don't see them come up for sale anymore, unlike rods and SR carbs.
Also, K172 intake taken off a fairly low miles SD in the late 70's.
Thanks for inputs
The Following User Says Thank You to bluebird455 For This Useful Post:
  #5651
Old 05-07-2024, 12:44 PM
Transamric's Avatar
Thanks for inputs
Whatever you decide that intake is worth, I want to be first in line to buy it. It's the last piece I need for my SD engine build.
  #5652
Old 05-12-2024, 11:23 AM
gevette gevette is offline
Default NOS cam
I would not be terribly concerned about finding a NOS cam. You can have an exact duplicate ground by several cam companies or have a modern take on the original that will be make more power. Once in the engine nobody will see it or know it wasn’t an NOS cam unless it is a totally different spec which would sound way different. It all depends on your goals for the project. Good luck.
I put a hydraulic roller in mine with specs similar to the RAIV cam but a modern updated style with a little more lift to optimize power.
  #5653
Old 05-12-2024, 11:40 AM
Default Driveshaft stripes 74 SD auto
On a 74 automatic SD what is the color of the stripes and location on the driveshaft? I’m restoring my driveshaft and lack this knowledge. Thanks
  #5654
Old 05-12-2024, 01:09 PM
Big Bear's Avatar
Big Bear Big Bear is offline
After blasting my shaft the rings were visible. Measusured from the yoke end flange to locate them. Used a picture from the internet for colors
ID:	633622   Click image for larger version
ID:	633623   Click image for larger version
  #5655
Old 05-24-2024, 02:02 PM
formula kid formula kid is offline
What is the purpose of the fuel accumulator? Why is a SD only. Also, is it only on 4spd car or is it on both?
  #5656
Old 06-06-2024, 08:50 PM
SD73's Avatar
I don't know what the function of the part was, but if I were to guess I'd think it was for vapor lock. It isn't an SD only item or 4sp Item. It's rather on cars before a certain VIN number. Attached is the bulletin on it.
  #5657
Old 07-16-2024, 12:22 PM
Verdoro 68's Avatar
Reposting here from my lobby thread on better decals. Does anyone happen to have an OEM SD valve cover decal to reference? I'm working on reproductions that use the correct brushed grain direction, fonts and dotted lines. I ran a small test batch, but think I've got a little more tweaking to do in terms of the color and transparency of the red. I'm also curious about what appears to be embossing on the orignals.
Original example:
My prototype:
My prototype vs. the existing repro:
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #5658
Old 07-19-2024, 09:29 PM
Brewster's Avatar
I'll look since I think I have one. Might take a bit since Im not to organized with this stuff.
Name:	Neils Pictures 092.jpg
ID:	637115   Click image for larger version
The Following User Says Thank You to Brewster For This Useful Post:
  #5659
Old 07-20-2024, 12:00 PM
71GP76TA 71GP76TA is online now
Not sure if this helps.
  #5660
Old 07-21-2024, 11:01 PM
Verdoro 68's Avatar
Thanks! Everything helps. The red looks richer and maybe not as transparent as the current repros. The embossing is more prevalent than I expected in your pics. I'm having a really hard time finding a place that can do it, but I think it's important for an accurate repro. I've been looking into companies that make wine labels and such, but they've all said they can't guarantee they'll withstand under hood heat.
Ken
'74 Ventura 350
'69 AMC Javelin SST
