Old 07-05-2024, 09:50 PM
400 4spd.'s Avatar
Originally Posted by BILL BOWMAN1 View Post
NOTHING. Already 88* and 73% humidity. Inside stuff only today. I’m going to enjoy a rare day off.
NOTHING done here either on one of my Pontiacs. The Grand Prix got attention early in the week. I spent the past two days working on my Corvette. Hot here, I took a pic of the shop thermometer at 6:30. Tomorrow will be worse.
ID:	636336   Click image for larger version
Name:	Corvette 7-5-24.jpg
The Following User Says Thank You to 400 4spd. For This Useful Post:
  #702
Old 07-05-2024, 10:06 PM
67drake's Avatar
67drake 67drake is offline
Geez. I’d be in the house till November.
I don’t do heat well, I had to put a window unit in my shop and running continuously. I don’t have to keep it cool, but it sure is nice with no humidity out there.
‘55 Catalina
  #703
Old 07-05-2024, 10:36 PM
400 4spd.'s Avatar
Tomorrow will be a few degrees warmer. I'll get an early start.
  #704
Old 07-06-2024, 12:42 AM
Jedwards80 Jedwards80 is offline
108-112 all this week. Sweating it out in the garage..I put in a new lock set this evening and installed some new adjustment screws in my headlight assembly. This weekend I need to redo the headlight grounds, install the headlights, the trunk lid needs adjusting, I need to install the taillights, rear trim, and back bumper, then clean the paint up a bit. We’ll see how much of that I get done before I retreat to the AC.
The Following 2 Users Say Thank You to Jedwards80 For This Useful Post:
  #705
Old 07-06-2024, 11:49 AM
carcrazy carcrazy is offline
Plan on getting the hoist out of storage today and removing the new engine for my 62 from the back of the truck.
The Following User Says Thank You to carcrazy For This Useful Post:
  #706
Old 07-06-2024, 12:39 PM
BILL BOWMAN1's Avatar
Cleaning work area will be about the extent of it today. I get to a point that I can’t take it anymore. I know there’s a workbench under all this crap!!
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #707
Old 07-06-2024, 01:24 PM
I get all my stuff done between October and march. Rebuilt the front end on my truck over the winter outside, work in the garage without any heat.. when I can see my breath, I’m in my happy place!
The Following 2 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
  #708
Old 07-06-2024, 04:38 PM
cleveweld's Avatar
cleveweld cleveweld is offline
Default Lots of cleaning
This morning I did a detailed cleaning of the engine compartment on my 1962 Tempest wagon. See the before and after pics below. Also cleaned exterior and wide white wall tires.
Last summer I finished insulating my garage/shop. In December I ran heat/AC ductwork out to the garage. A couple weeks ago I ran a second set of ductwork. See last pic.
Even when the temperature reaches over 100F, the highest the temp in garage has gotten is a cool dry 80F. The 2 sets of ductwork cost me less than $200 at Lowes.
Name:	Tempest model 018.jpg
ID:	636362   Click image for larger version
ID:	636363   Click image for larger version
ID:	636364   Click image for larger version
ID:	636365   Click image for larger version
The Following 4 Users Say Thank You to cleveweld For This Useful Post:
  #709
Old 07-07-2024, 02:48 AM
surfsama's Avatar
surfsama surfsama is offline
Heck, out testing a carburetor on an empty industrial road.
https://www.youtube.com/watch?v=Z9c4OLUEoWw
Only a pawn in game of life.
The Following 3 Users Say Thank You to surfsama For This Useful Post:
  #710
Old 07-07-2024, 09:40 AM
4dblnkldude's Avatar
I bought a 69 GTO judge clone on Friday.
The Following 3 Users Say Thank You to 4dblnkldude For This Useful Post:
  #711
Old 07-07-2024, 10:29 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default Norwalk Road Trip
So had the snowball effect happen. Took the 67 into the AC guy and the water pump went out. The engine was painted the wrong color when I bought it so it snowballed from there. New pump, hoses, ps hoses, chrome valve covers, air cleaner, aluminum radiator and engine repaint and detail all happened over the 4th and 5th. She’s ready to go now.
ID:	636396   Click image for larger version
The Following 7 Users Say Thank You to ponchjoe For This Useful Post:
  #712
Old 07-12-2024, 04:41 PM
Got the new rear bumper dialed in.
The Following 6 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
  #713
Old 07-12-2024, 07:04 PM
jhein's Avatar
jhein jhein is offline
Took my wheels in to have my new MT drag radials mounted. Same size as my BFGs, 255/60 15.
I've started messing around with my Dragy. But the combination of bad tires, bad surface and bad driver (me), means bad results. Now at least I'll have better traction and hopefully more consistency. I'm also thinking that for measuring tuning effects, I'll probably do some custom runs from a rolling start, something like 20-30 mph going up to 80-90 mph so it won't be as hard on the car and the tires. That will also eliminate my bad launch technique from the equation.
The Following 3 Users Say Thank You to jhein For This Useful Post:
  #714
Old 07-13-2024, 01:18 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Finished reading the owners manual of my 1926 Pontiac, which I trailered home Tuesday.
The Following 2 Users Say Thank You to Jack Gifford For This Useful Post:
  #715
Old 07-15-2024, 02:44 PM
jhein's Avatar
Just took my first drive with the MT drag radials. Wow! What a difference. I didn't do any launches or timing with my Dragy, just a relaxed cruise. But I did a couple rolling starts in 1st gear that would have literally fried the BFGs, and these things hooked pretty darn good. Very little spin, just go. Felt good cornering on a windy road too. Tomorrow I'll do some dragy tests.
The Following User Says Thank You to jhein For This Useful Post:
  #716
Old 07-15-2024, 03:30 PM
Verdoro 68's Avatar
I picked up a Dragy a while back too, but it hasn't been too helpful with the GTO. Like you, traction is the main issue
I've been eyeing a set of MTs in prep for a trip to the track at some point. Need to pick up some 15" wheels to mount them on.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #717
Old 07-15-2024, 04:17 PM
Would like to hear some reviews on the Dragy from you guys once you get things sorted out and get a few good runs. Maybe start a thread in the Street forum if you’re so inclined.
A pair of easy to find and inexpensive 15x7 Rally II wheels would accommodate some 235/60 or 255/60 drag radials and work pretty well.
I’m seriously considering getting one to see how my 421 convertible does. When I was thrashing it a bit from zero to about 90 in an effort to seat the rings it doesn’t really break traction from a standing start with the 2.56 open rear.
It should be consistent but not all that quick, if it breaks into the high 13s I’d be ecstatic.
The Following 2 Users Say Thank You to b-man For This Useful Post:
  #718
Old 07-16-2024, 03:57 PM
jhein's Avatar
Yeah, once I get a little more experience with it I'll post something in the Street section. The tires are a major improvement, but after some more launches and roll ins today, I can still break them loose so they're not the silver bullet I hoped they'd be. But still, much, much better than before.
One thing I will say now is that I don't think it's possible to duplicate track times on street surfaces no matter what you do. So if you think you'll get a Dragy to see what your car will do at the strip, think again. The exception to that would be if you have a car that doesn't break traction on street surfaces.
  #719
Old 07-16-2024, 04:02 PM
And for those of us who don’t intend on going to the track or worse don’t even have one within a reasonable distance can use the Dragy to at least get an idea and use it to compare their cars to others.
Knowing what it actually can do on the street is just fine because that’s where we’re going to be, as least 99.999 percent of the time anyway.
  #720
Old 07-16-2024, 04:07 PM
jhein's Avatar
Yes, I completely agree with that. It still has a LOT of value for tuning. Plus, it's just pain fun.
