Old 08-10-2024, 07:34 PM
Tim Corcoran's Avatar
Default Monday is Dyno Day Guess my HP & Torque
I am going to put my 400/467 on the dyno Monday
1970 400 bored to 4.18
Block fitted with Program Engineering 4 bolt caps
Line honed for the new caps
Block filled with hard block to 1/3 above bottom of water pump holes
Final hone of bores using a torque plate
Scat 4.25 forged cross drilled crank
Eagle 6.8 rods
Ross flat top piston 13:1 compression, pistons .003-.005 above deck
Cometic .040 head gasket
Edelbrock Old style combustion chambers
Average Intake flow @ .700 331.6 CFM
Average exhaust flow @.700 lift 249.4
219/1.77 valves, CNC Ported by SD Performance in Feb of 2007
Ultradyne solid roller 264/268 @ .050, 176/187 @ .200
.3944/.3944 Lobe Lift LSA 108
Crower 1.65 rocker arms
Victor with 8896 1050 Dominator home made 1-1/2 inch spacer 4 hold to open
1-7/8 Indian Adventures headers with Flowmaster 4-2-1 collectors
MSD Pro billet Distributor, MSD Blaster 2 Coil, MSD 6AL
Sunoco Purple 110 race gas
What HP and torque numbers do you predict
Tim Corcoran
Old 08-10-2024, 07:44 PM
Kind of close to my 500 but a you have a little more CR. I have 2" headers.
650 HP
Old 08-10-2024, 08:29 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I'll take a stab at it with 650 tq and 640 hp.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
The Following User Says Thank You to firechickenman For This Useful Post:
Old 08-10-2024, 08:43 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Old 08-10-2024, 09:33 PM
Scott Stoneburg's Avatar
660 HP / 570 lbft tq.
That's close to the 474 I used to run. You probably have a little better Cyl.Head
Old 08-10-2024, 09:36 PM
Good wishes to you Tim
663 / 613
Old 08-11-2024, 07:00 AM
My guess is 654 Hp.
I must add that with your compression and crank stroke I think that running 1.65 rockers on the exh side will hurt your all important average power numbers.
Can you make two pulls with 1.5 rockers on the motor?
Old 08-11-2024, 12:30 PM
engine dyno or chassis dyno?
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
Old 08-11-2024, 12:38 PM
Engine dyno
Tim Corcoran
Old 08-11-2024, 12:39 PM
My guess is 654 Hp.
Just exhaust or both
Tim Corcoran
Old 08-11-2024, 12:50 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I don't like guessing but good luck with the dyno session.
Go fast, see Elvis!
Old 08-11-2024, 02:30 PM
Just on the exh if your geometry does not go too far off the rails.
Old 08-11-2024, 10:51 PM
scott70's Avatar
scott70 scott70 is offline
Close to a engine I had done 640hp 595 trq
Old 08-12-2024, 01:49 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
640tq 610hp
Curious what timing and AFR when you're done was at peak numbers.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 08-12-2024, 06:26 PM
R 70 Judge's Avatar
601 TQ and 633 HP is my guess
James
1970 Trans Am
Old 08-12-2024, 07:43 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
I cant keep this drum roll up much longer! I can hardly wait!
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 08-12-2024, 08:28 PM
Sometimes no news isn't good news. Hope it went well
Old 08-13-2024, 01:14 AM
Fingers crossed its just a dilemma , not some kind of chaos.
Old 08-13-2024, 01:27 AM
Could have just been a very long day at the dyno cell….
622 hp - 590 tq
Old 08-13-2024, 07:45 AM
It was a long day on the dyno tuning the carburetor to improve the fuel curve and getting the timing ideal. The engine ran great and no leaks including the rear main seal was dry at the end of the day. Didn't have time to change rocker arms with 1.5's and I didn't want to pay for another day on the dyno. I will go back on Wednesday and pick up the engine and get the printed dyno pull sheets. Best pull was under 600 HP. I will tell more after I have dyno sheets. I had my street engine dynoed at the same place I think this guys dyno is not accurate. I believe the race track will tell a better story.
Tim Corcoran
The Following 5 Users Say Thank You to Tim Corcoran For This Useful Post:
