Old 08-18-2024, 10:54 AM
joes455 joes455 is offline
Default Lower crankshaft pulley inspection
This is just a heads up for you racers.Engine sounded like it was knocking ,this was the issue.You may want to check yours
ID:	638537   Click image for larger version
ID:	638538   Click image for larger version
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
The Following User Says Thank You to joes455 For This Useful Post:
Old 08-18-2024, 10:56 AM
This could have created a lot of damaged at 6000rpm
Old 08-18-2024, 11:46 AM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
funny you mention this as i had a noise i thought was the fuel pump eccentric. turned out it was 2 of the 4 bolts holding my crank pulley on were almost out completely. this was just 3 days ago. Tightened them all up with locktite and noise in now gone. that could've ended up real bad. Glad you found out as well before it was a bigger problem.
I am the Thread Killer!
