Old 09-15-2024, 05:02 PM
Jimbobeast Jimbobeast is offline
Default decals on air cleaner?
Did a 1970 RAIV engine have a "Keep your GM car all GM" decal on the air cleaner?
Car is getting close to being finished after only 22 years...
Judge decals are next.
ID:	639986   Click image for larger version
ID:	639987   Click image for larger version
The Following User Says Thank You to Jimbobeast For This Useful Post:
Old 09-15-2024, 05:51 PM
Held for Ransom's Avatar
No. No room for it either.
So long, farewell.
Old 09-16-2024, 09:37 AM
Jason67's Avatar
Jason67 Jason67 is offline
Default Ram Air Pan Decal
Looks like at least one RAIV pan escaped the factory with a "Keep your GM car all GM" decal according to this thread:
http://forums.maxperformanceinc.com/...+cleaner+decal
Is this wrong/incorrect information?
Jason
Old 09-16-2024, 12:03 PM
I've got an original RA III pan somewhere in the garage. I'll check that one. Right now it seems likely the "Keep GM All GM" sticker went on the air cleaner base.
Old 09-16-2024, 12:06 PM
Here is the photo from the thread mentioned above. Looks legit.
Old 09-16-2024, 02:51 PM
Definitely used on '70 RA3 GTO bases, have had two original 70 RA3 bases with faded out original gummed decals.
Old 09-16-2024, 03:50 PM
vertigto's Avatar
vertigto vertigto is offline
Nice GTO...congrats with finishing her up.
Also like your trailer...which manufacturer/specs?
Old 09-16-2024, 05:43 PM
I'd have to see the picture to be convinced, 'ol Pinion head.
The PP/6424826 was the silkscreened Pick code/PN used on '68/early '69. Reproduction here...
https://www.etsy.com/listing/1432901...irebird-pp-400
Pictured decal is a reproduction like this one...
https://www.amazon.com/1968-PONTIAC-.../dp/B06XVTNDP1
Another newer reproduction here...
https://www.firebirdcentral.com/1968...p/sti-2012.htm
1970 GTO air cleaner decals were...
Build sheet
Pick code - - Part number
PI/110 - - - ...6486110
PO/111 - - - ..6486111
PY/777 - - - ..6485777
PZ/778 - - - ..6485778
RAM/6RA - - - 478136 (RA 400/455, this was a shroud, not air cleaner)
RAM/5RA - - - 478135 (RA IV)
So long, farewell.
Old 09-16-2024, 09:21 PM
Trailer was purchased in 1996 from Tommy's Trailers in Ada, Oklahoma I believe. They are no longer in the trailer business.
All aluminum, 20', compartments for spare, ramps, electric winch. Pulls like a dream and optional front air dam keeps debris off the cargo. It has made the trip from Florida to Ohipo, Georgia, Illinois to GTOAA and POCI conventions over the years.
Old 09-17-2024, 07:12 AM
Jason67's Avatar
Default Ram Air Pan Keep Your GM Car All GM
Found this picture in my files I had labeled "original 70 RAIV pan". Don't know the story on it, but it has a decal placed on the driver's side. Can't make out the 2 letter code. Decal corners are not as rounded like repops.
Name:	Original RA IV Pan Drivers side sticker.jpg
Jason
