Here are the clearances I got ,arp studs torqued with arp ultra lube 130lbs rear 110lb 1-4
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Oh 400 stroker
Those clearances are so next year! Sorry, I had to.
If you just switched to studs then the clearance is secondary to the line bore being straight.
This needs to be checked first with a checking bar.
| The Following User Says Thank You to steve25 For This Useful Post: | ||
If it were mine i'd buy some .00 1 under bearings and put half on the uppers.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
For a 3" main engine it's loose, assuming measurements are correct. Were these measurements taken with plastiguess or a dial bore gauge?
When i built my 4" stroker, I shot for .0025-.00275" on all the mains. I think the rear main came out about .003. I was using a Scat crank with the journals on the small side and the main bores were on the larger side of spec. So I had to use FM 4040M1 bearings, they are .001" tighter than STD.
| The Following User Says Thank You to chiphead For This Useful Post: | ||
That seems loose to me based on my minimal experience. My mains are all around .0025 with the largest around .0027. I'd try some different bearings.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5 TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
You could also have your bearings coated to decrease the clearances. I have done that before and Calico's thick coating decreased the clearance by 0.0007-0.0008". But as Steve said, I would first check your main bores without bearings to check for concentricity and size. I have put main studs in before and they changed the size of the main bore compared to factory bolts and I ended up getting the main line done.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
IMO, too loose. I'd shoot for .0025 - .003
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
| The Following User Says Thank You to Gary H For This Useful Post: | ||
All measurements were done with a Fowler bore gage crank was measured with starlet mic ,I'll be getting it linehoned regardless .The vertical clearance was excessive due to crank being worn by .0005.Should the clearance get bigger or smaller as measuring closer it gets to parting line ?Also when checking saddle bores should they be perfectly round ?
I used to mock it up with bearings and crank, light film of oil, torque to value, rotate crank a few times, remove the crank, and take measurements w bearings in place.
That will give you the most accurate measurements. Is the workshop very cold? Temp-wise? .
I had to use King 0.001 larger halves to get mine just right plain STD were too tight. Mixing the 2 sets got me right on.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
| The Following 2 Users Say Thank You to chiphead For This Useful Post: | ||
Yes. And that's why I mock it up first, remove crank, torque caps to value, and measure with the bearings in place. (After crush)
That should provide readings as it would be in use. Or as close as possible. The lock/locating tabs on the bearings is an area that will not 'crush' much, or not as much as the rest of the shell. Old gearhead machinist suggested I do it this way a long time ago, and continue to do so. Try it both ways and take readings and see what you get. Will make a believer out of most. .
Skip that's how I got those clearances is with bearings installed.Just noted today that my bore gauge has spec sheet showing is calibrated to + - .0005.Anyways got out the plastic gauge and front bearing showed 2.75
| The Following User Says Thank You to joes455 For This Useful Post: | ||
Id run those clearances ...
My Half AN Injun..... |
Take it from a stroker guy that got .00495 on his mains and 8psi hot old pressure and yet the builder is going to be fighting me in court about it, those initial clearances of .0035 are great to him. LOL
New engine is .0028, great oil pressure.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
| The Following User Says Thank You to GOAT8U2 For This Useful Post: | ||
even without a spec sheet. Basic rule of da thumb-----between .0007 and.001/per 1" dia holds true for the TOP end of pressurized oil clearance fit. On a 3.500" main....your good. On a 3" main your OK...not the shoot for number but OK
Did you mic your bearings before setting them? Rule of thumb: clean and mic the bearings, mic the main journals then set the bearings and measure the bore diameter. Fowler is a pretty good basic bore gauge, but invest in a quality bore gauge graduated in .0001 instead of .0005.
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
I almost had the same clearance numbers . #1) 3.0 #2) 3.5 #3) 3.4 #4) 3.6 #5) 3.4
Been driving it all summer . Hot in gear oil pressure is 38 psi Cursing at 2000 rpm is 80psi.. I use 20/50 VR1 for oil..
