Old 01-04-2025, 12:06 PM
Chris-Austria Chris-Austria is offline
Default Pypes Street Pro vs Race Pro - comparison same car, 2 videos
Hi,
I just switched from the Street Pro muffleres to the Race Pro muffleres.
Everything the same except the mufflers, so you can hear the difference and get a little help to decide
1. Street Pro mufflers - similar sound to Flowmaster 40
https://youtube.com/shorts/ln0biiC776Q
2. Race Pro mufflers - similar sound to most straight through mufflers
https://youtube.com/shorts/PMXlY4OTbTw
I like both sounds, but the Race Pros are noticable quieter and deeper, which I prefer. Both are not quiet in my opinion, but the Street Pros are a lot more noticeable, especially at idle.
Any questions.... please ask
The Following 2 Users Say Thank You to Chris-Austria For This Useful Post:
Old 01-04-2025, 04:59 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I like the Race Pros, also. Sounds like a huge difference and this is fantastic documentation. Beautiful car, also.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 01-04-2025, 05:12 PM
thanks I had problems to find a good comparison between both, so I made one after I tested both.. I will keep the Race Pro's and sell the Street Pro's
Old 01-04-2025, 05:47 PM
Now you know why PYPES tells you right there on their website that the Race Pro mufflers are quieter than the Street Pro mufflers.
They weren’t kidding.
Old 01-05-2025, 11:01 AM
78w72 78w72 is offline
street pros are a chambered muffler like the slow-masters... race prose are a perforated straight through pipe with packing material in the case, like dynomax ultraflo's.
Old 01-05-2025, 12:50 PM
it's hard to tell the noise level, just because one muffler is quieter... the street pro's sound more old school, but are a bit too loud for me... the race pro's are loud as well, but have a more modern sound and will not draw as much attention at idle, which I prefer... I think for many the race pro's are too loud as well
Old 01-11-2025, 09:39 AM
I've switched back and forth between Race and Street Pro's on a couple different cars when experimenting. The Race Pro is definitely quieter than Street Pro's, despite what their names might insinuate.
The problem with both of those mufflers if you're looking for something quiet, is that they are short 14" mufflers so they are only going to muffle sound so much. Pypes doesn't make them any larger unfortunately.
That's why most people go for the Dynomax as they are available in 14" and 20" so if you're looking for something with a little more noise control, obviously the 20" will do a better job at that.
These days I typically always go for a Dynomax muffler, either turbo or welded case depending on application.
https://youtu.be/XqEydRRRwqE
Old 01-11-2025, 11:01 AM
Kenth's Avatar
Kenth Kenth is offline
No problem, there are 18" Race Pro mufflers as well:
https://www.pypesexhaust.com/product...vr30?sku=MVR30
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-11-2025, 11:09 AM
Looks like pypes now has a "turbo pro" muffler too, same basic design as the super turbo from dynomax, should be the quietest of all their mufflers.
Old 01-11-2025, 11:12 AM
18 is getting better. Must be a new addition since I last dealt with pypes. Looks like they are starting to follow dynomax's lead. Likely more people experienced what I pointed out and they are actually doing something about it. Good on them.
Old 01-11-2025, 11:25 AM
Shiny Shiny is online now
FWIW
Help me with this: "Not recommended on lower horsepower vehicles as low end torque may suffer."
Probably above my pay grade, but are they saying a highly restricted stock exhaust system will make my lo-po 350 happier?
At some point I need to replace the obnoxious glass packs with something way quieter so these sounded like a good option.... until the fine print caught my attention.
And "Think of these mufflers as large inhalers for your engine". Huh?
Mike
Old 01-11-2025, 06:14 PM
I don't know why that kind of literature is still found, it's the old "backpressure" wives tail again
Old 03-20-2025, 09:02 PM
Andretti's Avatar
Andretti Andretti is offline
I installed the Pypes 2.5" system with Race Pro mufflers last year on my '69. Fun at first but it does starts to wear on you after a while. The good thing is I get better mileage now since I'm a little more reluctant applying WOT...
