Old 02-01-2025, 11:40 PM
Verdoro 68's Avatar
Default '74 Ventura 2bbl lean condition
The 2bbl (7043062) on our '74 Ventura 350 has an off idle stumble that I've been trying to resolve. It's really pronounced when the engine is cold, so much that it will backfire or stall sometimes, but it's always there even when at operating temp. I figured it was going lean, so I welded in an O2 bung this afternoon and used my wideband to see what was going on.
The mixture is spiking to 15.5-17ish when I step on the pedal from idle (~14.0 AFR). It will cruise ok once you get past that initial spike and otherwise the mixture seems ok throughout the range. I've gone through several accelerator pumps trying to diagnose this. I can see that it's getting a good squirt of fuel immediately so I don't think that's the problem. I'm wondering if I need bigger jets. It's got 54s in it now which I believe are from the factory.
I know most folks have 4bbls, but figured I'd ask since these are similar to the center carb of a tri power.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-02-2025, 12:06 AM
Shiny Shiny is offline
Does this carb have a power piston for enrichment like a QJ? If so, is it possible you have a metering rod sitting too low in the jet or could benefit from a lighter spring?
Any chance richening the idle mixture could help?
Old 02-02-2025, 12:28 AM
Verdoro 68's Avatar
It has a power valve in the bottom of the fuel bowl between the jets that's spring loaded. No metering rods like a QJ.
I had the idle mixture richer (13.4) before I plugged in the 02 sensor and leaned it out.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-02-2025, 01:18 AM
Assuming the power valve is vacuum-actuated, is there any chance your vacuum has changed? For example, did your brake work introduce a vacuum leak?
Old 02-02-2025, 02:36 AM
Verdoro 68's Avatar
It crossed my mind, but I haven’t found any vacuum leaks yet. I supposed one way to test is to disconnect and cap all the vacuum ports on the carb and see if it runs better.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-02-2025, 03:12 AM
If it's like a QJ, the vacuum holds off the enrichment, correct?
If so, a vac leak wouldn't explain a lack of enrichment, would it? Although if the vac was so low that the valve never closed and you compensated by enriching the idle, then maybe?? I'd say get a vacuum gauge before assuming??
Or maybe it's all about your vacuum advance and the legendary "carb problem is an electrical issue" has snuck under your hood?
Might be worth verifying your vacuum advance can with a mighty vac and a timing light?
Old 02-02-2025, 03:26 AM
Verdoro 68's Avatar
It pulls a steady 19 inches of vacuum at idle, but I haven't left a gauge plugged in while we're driving to see what's going on. I picked up a new vacuum advance anticipating this potentially being a distributor issue. Will dig in more tomorrow.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-02-2025, 06:56 AM
What if anything else was done to the carb or the motor before this problem started up.
Was the carb sitting for months?
If so then the power valve in the bottom of the fuel bowl might be hanging up due to crap getting in the fuel bowl vent or simply from failed broken down jelled up gas.
Old 02-02-2025, 07:50 AM
Kenth's Avatar
Kenth Kenth is offline
I would:
1. Check inlet valve for correct style and size.
2. Check float settings.
3. Open idle tubes to .034".
4. Open idle needle holes to .075".
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-02-2025, 10:30 AM
77 TRASHCAN's Avatar
Does the power valve rod move freely?
I've had to un-stake some to polish the bore and piston.
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 02-02-2025, 02:44 PM
Verdoro 68's Avatar
It’s hard to say when this started. The car sat for 6 years before we got it. We did a bunch of things to get it roadworthy.
I went through and thoroughly cleaned the carb including removing the power valve and cleaning all passages. It moves free. I ensured the float is within spec. I tried two different needle and seats. Getting fuel to the bowl doesn’t seem to be an issue. It just doesn’t get enough to the engine when transitioning from idle.
What will opening the idle tubes and idle needle holes do?
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-02-2025, 02:53 PM
Kenth's Avatar
It will give better control of the idle needles, strong idle and more even transition to low-speed.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-02-2025, 03:23 PM
I forgot to mention what post 10 did.
That spring loaded rod must move without hesitation also, not just the valve in the fuel bowl.
That passage to each booster under the valve could be gummed up also .
And also that whole booster pump discharge cluster could have been put together with the wrong gaskets because as I recall the rebuild kits supply two different ones.
Old 02-02-2025, 03:24 PM
gto4ben gto4ben is offline
I did some checking and and your 2GC carburetor 7043062 was used in both '73 and '74 and had 7002654 jets (54) like you said and is for A, F, X automatic transmission cars Non-California.
The vacuum plumbing is rather complicated and there are many possible points for vacuum leaks. In addition, hot and cold temp switches can fail or their wiring breaks.
With my daughter's '71 LeMans with the 350 2GC and A/T, it had an off idle stumble from several causes.
The vacuum motor in the air cleaner had torn it's diaphragm and needed replacing.
The vacuum modulator hose at the transmission came off.
The distributor vacuum solenoid plastic nipples had cracks and the plunger did a poor job of sealing when activated. It got replaced.
I'd also check if your EGR diaphragm isn't leaking and it's got a good gasket seal and the vapor canister valving is in good shape. Check your radio fuse since it's used to power the TCS.
Check the throttle shaft for excessive play. The 2GC base is cast iron and usually doesn't experience wear like the quadrajets so I doubt it needs throttle bushings; however, I have seen cracks in the cast iron along the throttle shaft, perhaps from uneven tightening onto the manifold.
On my 455 with a '71 quadrajet, it had an off-idle stumble. Replacing the accelerator pump didn't cure it and no vacuum leaks were discovered. Crazy as it sounds, the cure was to adjust the mixture screws using the shop manual's lean drop procedure. I included those section's from the '74 shop manual for you.
Your 17:1 AFR lean measurement just off idle is a clue that the accelerator pump shot isn't enough to compensate. (Too much oxygen, not enough fuel combining with it in the burn). The idle and off-idle carb slots need to provide more fuel. I'd try the lean drop adjustment to find the spot where there do. Back in the '70's, inspection stations allowed as much as 4% CO and 400ppm HC for '74. Using your wideband sensor, set the mixture at idle to a hair above 13 at the factory idle speed and see if that improves the off idle stumble.
Name:	1974 vacuum hose routing AT.jpg
ID:	647009   Click image for larger version
ID:	647010   Click image for larger version
Name:	1974 Mixture Adjustment.jpg
ID:	647011   Click image for larger version
ID:	647017   Click image for larger version
Name:	Typical Vehicle Inspection Limits.jpg
The Following 3 Users Say Thank You to gto4ben For This Useful Post:
Old 02-02-2025, 04:28 PM
Verdoro 68's Avatar
Forgot to mention that I removed all the TCS stuff on the car and have disconnected the EGR.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-02-2025, 04:38 PM
It’s my understanding that if the EGR does not function then the motor will have a lean condition unless steps are taken to correct for having the EGR disconnected.
Old 02-02-2025, 04:45 PM
geeteeohguy's Avatar
If the EGR does not function the inert exhaust gas it would normally let into the combustion chamber won't enter, so the car will be more likely to ping. Although with a '73-'74, with low compression, doubtful. EGR only has vacuum on the carb side of the diaphragm, so if the diaphragm is torn, that would cause a ported vacuum leak if all the thermo switches still work.
An EGR not working in itself will not cause a lean condition unless the diaphragm is torn, which is not likely even on a 50 year old valve. Much more likely that in this case the carb is too lean for whatever reason.
Jeff
Old 02-02-2025, 07:06 PM
Verdoro 68's Avatar
Sounds like the EGR situation may not be helping. Th valve is still installed, I just unhooked the vacuum to it. The thermostat is switch is long gone and all the vacuum lines were rotted. With all the TCS stuff gone, the vacuum advance is now hooked up directly to a ported source on the carb.
I just tested the EGR and it holds vacuum. The vacuum advance does not so there’s a likely culprit.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-02-2025, 11:14 PM
Verdoro 68's Avatar
New vacuum advance didn't fully fix it, but it's better than it was. I am getting a full 36 degrees of advance now, too. I ran it with and without the EGR connected to vacuum. It actually seems to run a little better/richer with the EGR disconnected.
I'll take the carb apart again, remove the power valve and make sure everything's clean under there, then I'll try the idle adjustment procedure Ben mentioned above.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-03-2025, 04:09 AM
Schurkey Schurkey is offline
14:1 AFR is kinda lean for a carbureted idle. Connect a vacuum gauge to manifold vacuum, set the idle mixtures to lean best vacuum--achieve best vacuum. Best vacuum can be had with a range of AFR, you want the leanest AFR that allows best vacuum. Then lean-drop the vacuum about 1/4 inch on each of the two screws--about 1/2 inch, total. So a very slight lean-drop from lean best vacuum. A slight lean-drop eliminates a fair amount of tailpipe emissions without really affecting idle quality.
Spiking even higher at tip-in really sounds like an accelerator pump issue--but I am biased. I had perpetual problems with the accelerator pump on Mom's '77 Nova 305 with 2GV. I eventually installed a Cliff Ruggles-supplied accelerator pump which seems to have cured that problem.
If the pump were truly working, tip-in should show a momentary rich condition. We used to watch for a momentary spike in HC emissions when a tailpipe-sniffer (Exhaust-gas analyzer) was hooked-up.
The carb would have been set up for E-0; and I bet you're running E10. So going slightly richer may be warranted...but I don't think main jets are the problem here.
ANY misfire for ANY reason will cause an O2 sensor to report a false-lean condition.
Plugged passage on the power valve? Failed vacuum advance; advance connected to ported vacuum? Weak ignition coil? Failed pickup coil wires on an HEI distributor?
