Old 02-09-2025, 09:15 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Default ''69 GTO Ram Air on a budget
My GTO needed Ram Air. It's not a RA car, it's not a Judge, it's not even numbers matching, but what does that matter anyway. It's also a lot of $$ for either worn out original parts that need restoration or for a full repop kit that likely won't fit right without modification anyway. So why not work with what ya' have, buy the bare essentials, make the rest and modify it to work better.
I started by finding a used repop upper pan for sale locally and then bought the flapper assembly. It was at this time that I learned that Pontiac made two styles of ram air hood inserts and mine weren't the ones needed to attach to the flapper assembly. I've read nothing but horror stories about the aftermarket inserts, the OG ones are really expensive, and I don't have touch up paint for my car anyway, so I decided to just hog out the scoops on my car and make my own filler plates to keep the air moving through the flappers. I did this shaping some sheet metal and adding some metal strapping to attach the assy underneath the hood.
I also enlarged the opening in the upper pan as the one there seemed really small, and removed the vacuum diaphragms as I intend to leave this open for the mild weather here in So Cal.
ID:	647292   Click image for larger version
ID:	647293   Click image for larger version
ID:	647294   Click image for larger version
ID:	647295   Click image for larger version
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
Old 02-09-2025, 09:18 PM
Tuske427's Avatar
more pics of the flapper assembly
ID:	647297   Click image for larger version
ID:	647298   Click image for larger version
Instagram @tuske427
Old 02-09-2025, 09:20 PM
Tuske427's Avatar
Here are a few pics of the upper pan opening enlargement. Using the template helped me mirror the other side for a symmetrical shape and the one pic shows the material removed.
ID:	647300   Click image for larger version
ID:	647301   Click image for larger version
ID:	647302   Click image for larger version
ID:	647303   Click image for larger version
Instagram @tuske427
Old 02-09-2025, 09:25 PM
Tuske427's Avatar
The lower pan also required modification to clear my throttle body and electronics on the firewall. I did this by making a .75" ring with a piece of strap steel shaping it round and welding it to the pan. I trimmed back the rear and shaped an edge to clear the electronics. I added a strip of aluminum to help hold support the foam in front to keep it from deforming while inside the car.
I also cut down the lower foam seal as the pan itself is quite close to my hood and the foam may distort from squeezing too much. Yes, that's an electric knife- they work great for trimming open cell foam like this. I clamped this down and zip tied the trigger so I could use my hands to guide the foam through for a clean cut. Easy.
ID:	647305   Click image for larger version
ID:	647306   Click image for larger version
ID:	647307   Click image for larger version
ID:	647308   Click image for larger version
Instagram @tuske427
Old 02-09-2025, 09:32 PM
SD455DJ SD455DJ is offline
Wow, I'm impressed...very nice work.
Dennis
Old 02-09-2025, 09:34 PM
Tuske427's Avatar
First pic shows the cut edge of the foam with my electric knife. 2nd pic is my third arm holding it in place while I trimmed down that lower foam seal.
Lastly, I used one of those air filter lids to take advantage of any available airflow coming in as I had to use a 2" filter which isn't that tall and I didn't want to restrict the engine from air. I also don't like the idea that the air has to bounce off the filter lid and go around it to enter the engine. Seems inefficient to me.
All in I'm less than half of what a "kit" costs, and now my restomod GTO has what looks reasonably decent.
ID:	647310   Click image for larger version
ID:	647311   Click image for larger version
ID:	647312   Click image for larger version
ID:	647313   Click image for larger version
Instagram @tuske427
The Following User Says Thank You to Tuske427 For This Useful Post:
Old 02-09-2025, 10:07 PM
433lemans's Avatar
433lemans 433lemans is online now
Nice job! I like it.
The Following User Says Thank You to 433lemans For This Useful Post:
Old 02-09-2025, 10:23 PM
Verdoro 68's Avatar
Looks awesome. You've done some cool projects to that car.
Ken
'74 Ventura 350
'69 AMC Javelin SST
