Old 02-27-2025, 11:36 PM
67Lemons 67Lemons is offline
Default eBay tubular control arm bushings?
Has anyone replaced the control arm bushings in the ebay 64-72 A Body tubular arms & have a part number or application?
ID:	648188   Click image for larger version
ID:	648189   Click image for larger version
Old 02-28-2025, 04:16 PM
JLMounce JLMounce is offline
You want the Global West bushings.
Uppers should be part 1030 and lowers should be 1055. I would call them to absolutely verify though.
-Jason
1969 Pontiac Firebird
The Following 2 Users Say Thank You to JLMounce For This Useful Post:
Old 03-01-2025, 11:12 AM
Thank you Jason, I think you’ve cracked the code on these arms. I’ve searched everywhere & no one can say what bushings to use. It looks like from your suggestion the bushings are for Corvette arms up to 1982 & full size Chevy arms up to 1970. I’m ordering the Moog versions to confirm since this is more for a cruiser car than protour feel. I’ll update this once I test fit the bushings, thanks!
Old 04-10-2025, 03:26 PM
grivera's Avatar
grivera grivera is offline
Any update on which bushings worked? Also, which ball joints did you use?
Will Rivera
Old 12-28-2025, 06:23 PM
I ended up selling the arms so never installed the bushings. I should have swapped them out first but didn’t get around to it.
1972 GTO
