Old 03-06-2025, 03:13 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
Nice Ken,! I definitely have to check that out as I am in the market to buy a distributor. Where did you buy that?
  #1102
Old 03-06-2025, 08:30 PM
Verdoro 68's Avatar
Directly from Progression Ignition. It's pretty cool tech if you're into that sort of stuff.
https://progressionignition.com/prod...gories/pontiac
I'm trying to figure out a good curve to start from. I suppose the easiest way to start is to document how the current distributor in my car is curved and transfer that over.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #1103
Old 03-09-2025, 10:27 PM
67drake's Avatar
67drake 67drake is offline
60 degrees here today. I figured I’d get the cars out for some exercise. Took each one on about a 20 mile loop.
ID:	648702   Click image for larger version
ID:	648703   Click image for larger version
‘55 Catalina
The Following 6 Users Say Thank You to 67drake For This Useful Post:
  #1104
Old 03-10-2025, 12:19 AM
Verdoro 68's Avatar
Busy weekend on the cars. Great weather for tinkering.
I went to install the Progression distributor on the Goat thought I'd warm it up so I could write down the current advance curve. I fired it up and within a couple minutes the idle got erratic and the car shut off. I installed a new fuel pump a few weeks ago and apparently it wasn't up to the task. The end of the arm broke off inside the pump!
Fortunately, I saved the old one, reinstalled it and was back in business. It took about an hour to install the distributor - super cool piece. I didn't get to take the car out because we were finishing up the carpet on the Ventura, but I did get an initial curve dialed in.
Back on the Ventura...I wasn't happy with the green paint the shop mixed up as it was too light and I went on the hunt for something closer. I probably went through 10-12 different off the shelf greens before finding Krylon Italian Olive which is almost an exact match. So, we repainted all the interior plastic. Cole had to work on Sunday so I kept going and installed a new package tray, new a/c vents, reinstalled the repainted panels and finished with new sill plates. Got things wrapped up just as the sun went down.
Original mix by the paint shop is on the rear door panel and part of the kick panel:
Some of my green paint collection:
The winner!
Repainted rear door panel:
ID:	648706   Click image for larger version
ID:	648708   Click image for larger version
ID:	648709   Click image for larger version
ID:	648710   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 5 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1105
Old 03-10-2025, 04:46 PM
Stibley's Avatar
Stibley Stibley is offline
Finally got around to fitting my new Summit Racing mini starter which was a royal pain as the mounting block fouled the headers. After removing a small amount of the mounting block all was good. Sorted the poor earth strap mounting point from the engine to the chassis mounting. Fitted a new gearbox modulator, and sorted a minor oil leak from the oil pump/pressure gauge line union. Fitted another new set of ignition leads as I didn't like the neon blue ones I bought the previous week. All that and manged to get in a local car show at the Krispy Kreme and win first prize (Box of KK doughnuts minus 4 for my friends at the show). Good to to see the sun out and the start of the car season!
ID:	648730   Click image for larger version
ID:	648731   Click image for larger version
ID:	648732   Click image for larger version
The Following 4 Users Say Thank You to Stibley For This Useful Post:
  #1106
Old 03-11-2025, 01:15 PM
Default Landmark day
Had ACP Classicos (Portugeuse AAA) haul the Lemans to an exhaust shop to repair damage done by the Customs warehouse. They did superb work.
Chanced driving back as the weather has been constant heavy squalls and the wipers are not working. Going across the Ponte Vasco de Gama.
Cost about $105 to fill the tank with 95 Simple (they have 98 too).
Name:	Ponte Vasco de Gama.jpg
The Following 6 Users Say Thank You to Scarebird For This Useful Post:
  #1107
Old 03-11-2025, 04:56 PM
looks nice there....
Old 03-13-2025, 05:27 PM
it is, king buzzo.
Found the fuse blown in the wiper circuit. Why? I noted that the plug into the motor was just connectors (no plastic plug until I get the delay sorted) and rather tight - so it seems 2 of the wires touched.
So some shrink tubing electrically isolated it and now they work. Good thing too as I visited my insurance agent and got caught in a pretty good squall.
A bit ago I was trying to decide what car to bring over. Given the long doors, small trunk and worse mileage the Trans Am was sold. Good thing as I am dumbstruck how many people notice this old girl. Most of the cars here are black, white, silver or gray. Lucy Blue sticks out but good - the TA would have been too much!
  #1109
Old 03-13-2025, 07:30 PM
carcrazy carcrazy is offline
Well I walked past my 62 GP today and thought.......maybe tomorrow!
The Following 2 Users Say Thank You to carcrazy For This Useful Post:
  #1110
Old 03-13-2025, 08:02 PM
Installed a new set of wide oval radials and added trim rings to the KR wheels. They reduced the price on the tires by $150/ea so I sad screw it and bought a set.
White cars look too plain without trim rings IMO.
And no... there is nothing wrong with the front end.. Pic was taken at a weird angle and the tire is turned at a weird angle..
And yes... it's dirty because I drive it...
The Following 6 Users Say Thank You to 71GP76TA For This Useful Post:
  #1111
Old 03-14-2025, 09:56 AM
73_Lemans_350's Avatar
73_Lemans_350 73_Lemans_350 is offline
Took my LeMans out for a cruise! Beautiful night. Now we await a winter storm.
ID:	648902   Click image for larger version
ID:	648903   Click image for larger version
Design Engineer | Dakota Digital
1973 Lemans - 350, Centerline Auto Drags and Cooper Cobras
The Following 5 Users Say Thank You to 73_Lemans_350 For This Useful Post:
  #1112
Old 03-16-2025, 12:21 PM
The main shop is on hold currently, finding a contractor that returns emails is tough here. A mechanic friend here has a close friend who does this sort of masonry thing. I am having him enclose a walkway and convert it into a garage - the Lemans snuck in and notes it's approval:
Some friends had me over for dinner, they noted a car swap meet thing going on in our hometown. So the old girl rumbled down for a visit. To say this car turns heads would be a British-level understatement. So entering the complex (local expo center) was interesting. They put the Lemans right up front. There was a lot of other interesting kit about; a 74 (?) Mk. II Escort - very clean lines, Minis, buncha 2CV's and a lot of BMW's.
Inside was mainly motorcycle stuff; not much in the way of intakes, cylinder heads etc. A lot of toys and for some reason multitudes of headlights. There was of course a functional bar that even at 10:30am was doing a land office business. Portugal...
My friend Andre turned up and gave a nice tour. By the time I finished the inside the number of cars outside had tripled. The Pontiac was soaking up attention.
Strangely, no other car had their hoods up? A couple spots down was an early 70's Opel.
I wonder if GM used the same colors over here?
Name:	Garage early.jpg
ID:	648969   Click image for larger version
ID:	648970   Click image for larger version
ID:	648971   Click image for larger version
Name:	Opel moita.jpg
The Following 3 Users Say Thank You to Scarebird For This Useful Post:
  #1113
Old 03-16-2025, 12:36 PM
Update on paint:
The time period shows a Blue running in availability the same time as Lucy Blue, even though the codes are different. My guess is they are the same:
Exterior Colors - Factory Code, Name, Plaque Number
1969 Colors
15 - GT Metallic Green / Forest Green - 336
BB - Sand Beige - 448
CC - Sun Yellow - 450
DD - Regal Gold Met. - 447
HH - Strato Blue Met. - 235
JJ - Rallye Red - 520
PP - Spring Green Met. - 338
RR - Brilliant White - 451
UU - Metallic Silver - 135
1970 Colors
16 - GT Chartreuse - 406*
CC - Chrome Yellow - 446
DD - Aztec Gold Met. - 404
GG - Copper Bronze Metallic - 507
JJ - Flame Red - 508
PP - Spring Green Met. - 308
SS - Sunburst Yellow - 407
WW - Rallye Orange - 513
ZZ - GT Chartreuse - 406*
* Some sources have this as ZZ, others as 16.
1971 Colors
CC - Alpine White - 416
DD - Strato Blue Met. - 235
GG - Aztec Gold Met. - 404
HH - Jade Green Met. - 304
PP - Astro Silver Met. - 135
QQ - Rallye Gold - 411
RR - Flame Red - 508
TT - Antique Bronze Met. - 412
XX - Fire Glow Orange - 529
YY - Chrome Yellow - 446
1972 Colors
CC or RR - Alpine White - 416
DD or HH - Strato Blue Met. - 235
HH or PP - Jade Mist Met. - 303
QQ or SS - Rallye Gold - 411
RR or JJ - Flame Red - 508
TT or GG - Antique Bronze Met. - 412
XX or WW - Fire Glow Orange - 529
YY or CC - Chrome Yellow - 446
UU - Astro or Grecian Silver Met. - 135
1973 Colors
SS - Grecian Silver Met. - 135
  #1114
Old 03-16-2025, 03:56 PM
67drake's Avatar
Last night I finished wrapping up an 8.5 A body rear end to ship out. 129 lbs. with probably 10lbs of tape and cardboard!
ID:	648984   Click image for larger version
‘55 Catalina
The Following 3 Users Say Thank You to 67drake For This Useful Post:
  #1115
Old 03-16-2025, 09:53 PM
nbn nbn is offline
Wife pulled the driveshaft and front springs from the parts shelf. She sanded the driveshaft and blasted the springs.
I was relegated to painter for those pieces.
The Following User Says Thank You to nbn For This Useful Post:
  #1116
Old 03-16-2025, 10:45 PM
Verdoro 68's Avatar
Tore the dash apart on the Ventura. Painted the dash and column. Replaced the broken a/c and heater cables. Cleaned all the ducts and installed new foam seals so there will actually be some air flow when we get this thing back together.
Cleaned up the dash housing and took a chrome pen to all the highlights. A few years ago Shiftworks made a tach that fit in the clock blank. They've been discontinued a while, but I found one on Marketplace a couple weeks ago, so we installed that in the freshened up housing and cluster.
Took the Goat out and tinkered with the new distributor. I like it.
ID:	649016   Click image for larger version
ID:	649017   Click image for larger version
ID:	649018   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 6 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1117
Old 03-16-2025, 11:06 PM
67drake's Avatar
Did some research and figured out what parts to go with for my 400 rebuild. Ordered rings, main and rod bearings, oil pump and drive, and timing chain. Gotta get back out in the garage now that it’s warming up a little.
‘55 Catalina
The Following 2 Users Say Thank You to 67drake For This Useful Post:
  #1118
Old 03-17-2025, 05:44 PM
I ordered a ton of parts from our host over the weekend. The fan shroud, the AC rad seals, all the clips, etc. Fuel lines. Also ordered virtually all of the emblems, the wheel well mouldings, the quarter panel gills, and then some interior parts.
This is all in anticipation of getting the car cleaned up and wrapped in vinyl. We got a price of about three thousand dollars from a place that we know does great work. Painting is out of the question. The order of magnitude estimates that we received were insane. We think that the car will look presentable with a satiny wrap in the closest color to the original Montego Cream, with the new emblems and everything. Anything else we will polish as best we can.
Also ordered a bunch of stuff from Rock Auto. I'm hoping that a "Low Profile" fan clutch will position the fan blade back from all the way into the shroud. I guess the present location in relation to the shroud is a result of an 11 bolt water pump on our '67.
The list goes on. New wiper motor, all new front brake lines for the disc brakes, rebuilt 4 piston calipers, etc. So were going to be busy.
The Following 2 Users Say Thank You to 66sprint6 For This Useful Post:
  #1119
Old 03-17-2025, 10:06 PM
Not a damn thing...
  #1120
Old 03-18-2025, 08:44 AM
I did a little pre driving season Maintenance on the Mallett Solstice, Oile & filter change, rotated the tires. Stareted thinking what else needed to be done before Driving it in June from Michigan to Taos NM. I looked and the Colant and Brake fluid are now 5 years old so time to change those out. Maybe do a fuel injection clean and change the original 19 year old spark plugs, they only have 53K on them but better here than somewhere along Rt 66 in June!
