Old 03-29-2025, 04:17 PM
grivera's Avatar
grivera grivera is offline
Default Brake Pedal Pushrod Length - Manual Brakes
Is there a specified clearance needed for the brake pedal pushrod and the piston in the master cylinder for manual brakes? The car is a 66 Lemans with aftermarket 2 reservoir master cylinder.
Will Rivera
Old 03-29-2025, 05:35 PM
65 Lamnas's Avatar
I set the clearance by "feel". Make sure you're in the upper hole on the pedal. Extend the push rod until there is no longer any clearance, then shorten it by 1/2 turn, lock the jam nut and call it good. If you were running power assist brakes is when you would use the lower hole in the pedal.
The Following User Says Thank You to 65 Lamnas For This Useful Post:
Old 03-29-2025, 05:37 PM
grivera's Avatar
Thank you! Will give that a go
Will Rivera
Old 03-31-2025, 09:10 AM
grivera's Avatar
It turns out my brake pedal return spring is missing. Gotta find a source for one. Searching the Ames website by keyword is worthless.
Will Rivera
Old 03-31-2025, 09:17 AM
Elarson's Avatar
Elarson Elarson is offline
Old school Ames paper catalog is better for searching.
Eric
Old 03-31-2025, 09:51 AM
grivera's Avatar
I emailed Ames and was advised it doesn’t use a spring. I see the hole for it and it has the little tab on the clevis pin. I think I e seen a diagram showing it.
Will Rivera
Old 03-31-2025, 11:51 AM
400 Lemans's Avatar
http://forums.maxperformanceinc.com/....php?p=6468974 Good pic of it here in #5 post.
Old 03-31-2025, 12:49 PM
grivera's Avatar
Thank you - that is great. May have to source an off the shelf spring.
Will Rivera
Old 03-31-2025, 07:24 PM
grivera's Avatar
Found the spring at Musclecar Central: https://www.musclecarcentral.com/196...p/ppd-831b.htm
Will Rivera
