Old 03-31-2025, 05:53 PM
67FB 67FB is offline
Default Forward Facing Stock Manifolds
I’m in the planning stages for my turbo build and I didn’t see much info on using flipped stock manifolds. It seems like they would work. This is going in a first gen Firebird. Is there not enough clearance when in the car to make the bend off the manifold heading forward?
ID:	649699   Click image for larger version
Old 03-31-2025, 08:50 PM
turbo69bird's Avatar
Idk never did it that way. I used to make a turbo kit for the first gen and some guys on here still had some unused sets. But the
logs are fine up to a certain HP
This will give you a good idea of how they Ran for the first gen
Feels like that was. A lifetime ago now
ID:	649707   Click image for larger version
960 HP @ 11 psi, 9.70 at 146.
The Following 3 Users Say Thank You to turbo69bird For This Useful Post:
Old 04-01-2025, 06:49 AM
charlie66's Avatar
It most likely does. I have a Ventura, and it has a lot of clearance. I'm assuming that yours should be simular .. You can probably find different stock manifolds that exit on more of an angle, more like a Y configuration ..
My Half AN Injun.....
Old 04-01-2025, 10:21 AM
Thank you for the pics and responses. Yes, it seems like there will be enough clearance. I’m surprised more people haven’t tried it. I update my slow progress as I go.
The Following User Says Thank You to 67FB For This Useful Post:
Old 11-30-2025, 04:18 AM
blueghoast's Avatar
Time for an up date ?
GT
Old 12-24-2025, 12:10 PM
R 70 Judge's Avatar
If I remember correctly, the driver's side manifold on a 1963 Le Mans with the 326 faces forward from the factory. That may be an option
James
1970 Trans Am
