Old 04-25-2025, 05:03 PM
Held for Ransom's Avatar
Size Identifier. I don't know where I've seen it...
So long, farewell.
  #282
Old 04-26-2025, 02:59 PM
They're next on the list to call. Just Dashes wants an extra $600 for bright blue. Jeez
Just Dashes did mine 25+ years ago, in black, and at that time they sold me the dye for the blue, and I did it myself. Which was good, because that way I could use it on the other interior pieces to ensure they all matched. Not sure if JD stills sells the dye separately, but mine still looks great after 25 years. Prep is critical, of course.
  #283
Old 04-26-2025, 04:23 PM
72projectbird's Avatar
I don't necessarily have a problem with dyeing the dash or other pieces, it's the fact that they want $600 additional dollars to do it.
I already have the paint for the steel interior parts mixed and sprayed out (steel dash, A-pillars, headliner trim, rear package tray window trim) and that wasn't anywhere near $600 lol
I'll figure it out and settle on a dash company soon. The rest of the interior still has a while before it ships. Plus I still need to get the wiring harnesses in before any interior work.
Question: Who do you guys recommend for the gauge bezel restoration? It's actually in pretty decent shape, and I'm almost hesitant to restore it, but I'm afraid if I don't it'll stick out like a sore thumb.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #284
Old 04-26-2025, 08:06 PM
Source a junky later 70s bezel and experiment with it.
Supposedly a good application or two of Easy-Off oven cleaner removes the old clear coating.
Then you neutralize it ,
Prep-Sol
De-lint
Respray high end clear coat.
Or , wait on Randy Combs to do it professionally.
I would not lay a finger on an early bezel until I had experimented with another one of little value.
  #285
Old 04-27-2025, 12:18 PM
Prep-Sol
De-lint
I have stacks and stacks of later bezels, so I could experiment on them. I wouldn't touch a 70 bezel myself unless I was extremely confident in my abilities restoring bezels, which right now I am not.
Speaking of other 70 specific items, I need to start thinking about sending the headlight bezels out to chrome. They're in ok shape, but certainly won't cut it on this car now. I might run reproduction pieces until I decide on a plate shop.
I'm also getting ready to order the exhaust. I'm going with Gardner, unless you guys have another recommendation?
1987 Grand National
  #286
Old 04-27-2025, 04:24 PM
Formulabruce's Avatar
Garner is a few months out, and is the best. They actually have factory exhaust there they make it from. Just make sure muffler is tilted and install it from rear to front. Their tips are 100% better than factory. I have had 70 and 71 NOS tips and Gardner tips are far superior in quality and finish.
" Long may we DRIVE !"
  #287
Old 04-28-2025, 11:44 AM
Awesome!
Now that the hardest work is done, we're running into extended wait times for specific parts. The interior is taking a little while, the dash is going to be an ordeal, the Coker tires won't be in until at least July, and now we can add the exhaust to the list lol. It's ok though, we're only doing this once!
1987 Grand National
The Following 2 Users Say Thank You to 72projectbird For This Useful Post:
  #288
Old 05-03-2025, 09:35 PM
Prep-Sol
De-lint
I believe I was able to get the yellowing original clear coat off mine with lacquer thinner. And then just carefully cleaned/degreased, and re-cleared it. But I would definitely experiment on a junk part first.
  #289
Old 05-06-2025, 11:47 AM
Anyone here have a pic of a 70 AM radio? I'm looking for one, as the original is long gone. I know there were differences across vehicle platforms, despite the radios being mostly the same.
1987 Grand National
  #290
Old 05-06-2025, 04:20 PM
The car is almost back on its feet! The blasting, repairing and painting of smaller components is underway.
1987 Grand National
  #291
Old 05-08-2025, 02:36 PM
Some more pics. The hvac is starting to go in. The interior hvac suitcase was blasted, bodyworked and painted, with all new internals. New firewall insulation pad. Other components like the column, pedals, e-brake and brackets are all blasted and prepped for paint.
1987 Grand National
The Following 3 Users Say Thank You to 72projectbird For This Useful Post:
  #292
Old 05-22-2025, 12:19 PM
I sent the dash out to be redone, and got the original radiator dropped off to be re-cored. I tracked down an AM radio that looks the part, but I need knobs for it. Can anyone confirm what the 70 knobs look like?
1987 Grand National
  #293
Old 05-22-2025, 12:56 PM
I used Sanford radiator for my 1970 4 core. It's beautiful, but was almost 1k dollars.
  #294
Old 05-22-2025, 04:19 PM
SD455DJ SD455DJ is online now
I'm pretty sure that they were all the same...black with chrome accents.
Dennis
  #295
Old 05-22-2025, 10:00 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Sorry I may have missed it but is this intended as a concourse level restoration?
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
  #296
Old 05-23-2025, 01:43 PM
I just dropped it off there the other day. Super nice guy, and extremely knowledgeable about all things radiators. He knew it was out of a Firebird before I said anything haha
Dennis
Thanks for the pic!
Pretty close to one. There's a few liberties taken, such as no overspray on the red oxide floors, and the paint being wet sanded up to 5000 grit before being buffed to a mirror. That said, it's a pretty damn correct car.
1987 Grand National
  #297
Old 05-24-2025, 06:35 PM
srmmmm's Avatar
srmmmm srmmmm is offline
I have an actual 1970 AM radio available to purchase. This came from a 1970 Esprit, VIN 224870N121659 purchased new by my father and in my possession since 1974. The option list included the rear speaker. It was working when the vehicle went into storage in 2004.
PM if interested at $100.
ID:	652043   Click image for larger version
ID:	652044   Click image for larger version
The Following User Says Thank You to srmmmm For This Useful Post:
  #298
Old 05-27-2025, 01:50 PM
About to start the resto on the wheels. The fact that all 5 match after 55 years is crazy.
Looking at them, and pics of restored cars, it looks like the inside of the rim (facing the brakes/frame) are primer, not paint. What are you guys liking for replicating the original finish? It looks like a light gray primer, with maybe a very small touch of blue in it?
Also, how should I finish them? I've seen a few with high gloss clear on them, which doesn't look bad but definitely not an original look. I just want to keep the brake dust from embedding into the paint, so I was thinking about satin clear, but I'm open to suggestions.
1987 Grand National
  #299
Old 05-27-2025, 02:57 PM
Backside is a dove grey paint and has a bit of sheen but not a full distinction of image type gloss.
Satin or Eggshell clear on the front is what I would want.
  #300
Old 05-27-2025, 04:38 PM
Last set of these I did for the backside I used DP40.
Now it's DP40LF. It's epoxy , so it will last and look the part.
