Old 04-09-2025, 08:35 AM
77screaminchicken 77screaminchicken is offline
Default 77 T/A dated W72 parts needed
Good morning everyone!
Building a 77 Y82 4 spd car thats missing her original engine. Trying to put together the most correct replacement that I can. I am in search of a WA block dated November of 76 ideally. Also 6x4 heads and an intake part # 525355 in the same date range!
Old 04-09-2025, 08:42 AM
burd's Avatar
burd burd is offline
lol, I just scrapped out a set of heads.
All I have left is a water pump off a w72, and the alum goose neck.
Southern Hamtramck Institute of Technology , Alumni
Put some 8” flakes and BFG’s on dude!, like everyone does🙄
Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers.
1978 YEE
1995 Q45
#whoremembers
Old 04-09-2025, 08:50 AM
ahh just my luck 😂 what is the date on the water pump sir?
Old 04-09-2025, 08:53 AM
burd's Avatar
I will get it out today and look, from what I remember it was off a 78;w72.
Heads are tough, no one wants to ship, they were up here for a long time.
1978 YEE
1995 Q45
#whoremembers
Old 04-09-2025, 09:28 AM
sounds good brother thankyou! Yea thats true, might have to start hitting the swap meets!
Old 04-09-2025, 09:54 AM
Jay S's Avatar
Jay S Jay S is offline
I don’t know where your at, but I have a standard bore 77 WA that spun a main. The block would need to be line bored or need shim stock on that main to be saved.
I also have a balanced and fresh machined (.020”/.020” with all bearings) rotating assembly stock stroke 3.75” (for Eagle H beam rods) with 4.15” ICON flat top forged pistons. I used the connecting rods on another engine, would need another set of eagle connecting H beams.
I am in SE Nebraska.
Old 04-09-2025, 12:51 PM
whats the date code on the block sir? im in central Texas
Old 04-10-2025, 09:14 AM
Jay S's Avatar
Appear to be later than your car, It isn’t easy to read, but appears to be
E127
May 12 1977
It came out of a 4 sped TA in the KC area that was salvaged.
Old 04-27-2025, 11:46 PM
any word on that water pump?
Old 04-27-2025, 11:48 PM
also searching for a distributor part number 1103271 and 55A alternator p# 1102478 ideally with a november of 76 build date
Old 04-28-2025, 02:03 AM
Ramairnacho Ramairnacho is offline
alternator for ta w 72 in 77 or 78 is 1102854 heavy duty and I got one. PM me if interested dated j of 1976, i know I have 1102480 and 1102486 too
Old 04-28-2025, 08:30 AM
awesome, what amp is the 1102854?
Old 04-28-2025, 03:30 PM
Default alternator
63 amp
Old 04-28-2025, 04:31 PM
ahh unfortunately i need a 55 amp in order to be correct for my car. Had ac but no power windows or doors and no defrost
Old 04-28-2025, 05:49 PM
Default alternator
I believe it's correct part of w 72 package but I might have a 55 amp alternator look.up wallace racing alternator codes. it was my impression that all w 72 cars got the HD alternator .
Old 04-28-2025, 09:19 PM
yea its been tough finding verifiable information on what the correct alternator is for certain. Hoping to learn more on this forum.
Old 04-29-2025, 12:28 AM
Default alternator
do you have build sheet or phs docs?
Old 04-29-2025, 08:15 AM
i have phs only!
Old 04-29-2025, 07:41 PM
PHS won't help with the alt part number. Buildsheet would only show the correct two letter code for the original alt then you would have to decode.
Here's the actual '77 model 400 T/A or Formula usage:
1102478 55 amp...... AC or heated rear glass
1102492 37 amp...... non AC
1102854 '63 amp..... AC & heated rear glass
Looking myself for a Dec '76 dated "2478".
Will find one, get into quite a few boneyard stocks.
Old 04-30-2025, 09:12 AM
burd's Avatar
Look at a buildsheet from another car like yours, I know a guy w/ a data base of them, you can buy a blank one, make one for your car the best you can. PHS isn’t much good.
Without a BS, doing a numbers match car is pointless.
1978 YEE
1995 Q45
#whoremembers
