Old 05-15-2025, 12:22 PM
tj.brewster tj.brewster is offline
Stan, Any plans on making more of these? Just starting my project. Also what's the cost on these?
Thanks, TJ
  #522
Old 05-15-2025, 12:37 PM
Stan65 Stan65 is offline
tj.brewster,
I have the machine shop making a few more. Basically using up the material they have on hand.
Have 1 set of the last run left. I’ll send a pm.
Thanks,
Stuart “Stan” Landreth
  #523
Old 06-29-2025, 03:08 PM
All,
Just finished what is likely the last run of the bones. The cost of the material and machine shop time going forward will just be too expensive and I believe will put the cost beyond what most will spend.
This is the last 12 sets which makes 96 sets!
Thanks,
ID:	653563   Click image for larger version
ID:	653564   Click image for larger version
The Following User Says Thank You to Stan65 For This Useful Post:
  #524
Old 06-29-2025, 05:13 PM
VCho455's Avatar
VCho455 VCho455 is offline
PM sent.
  #525
Old 06-29-2025, 06:14 PM
tempest1964's Avatar
Stan, thanks for a great service to the hobby!
The Following User Says Thank You to tempest1964 For This Useful Post:
  #526
Old 06-29-2025, 09:34 PM
65madgoat's Avatar
Can you give me an update on what roller lifters are being used today with this conversion? I was told the current Sealed Power lifters that had been ideal and now made in China and do not work any more.
  #527
Old 06-29-2025, 09:40 PM
65madgoat,
The sealed power HT2148 lifters and the other but more costly are Howards (Gaterman) 91174
The Howards lifter is in the bottom .
If you use sealed power make sure the oil feed hole looks exactly like to one on the top.
Thanks,
  #528
Old 06-30-2025, 08:03 AM
P@blo's Avatar
P@blo P@blo is offline
We should compile a list of cams that guys are using for this modification.
Great wotk Stan! Any seniors discount?
  #529
Old 06-30-2025, 10:16 AM
P@blo,
I wish I could give senior, veteran, and first responder discounts, but unfortunately I only make $10 a set for my time to box and ship them. I probably use that up in gas.
I made these for myself and a few fellow PY’rs talked me into making a batch as they wanted a set. That turned into several batches. The demand has dropped off as most folks interested have already purchased. Not worth my time to advertise to break even. Just wanted to contribute to the hobby.
As far as cams, if you look back through this thread, you will see a couple of guys posted their successful cam setups. Here is mine.
Thanks,
The Following 3 Users Say Thank You to Stan65 For This Useful Post:
  #530
Old 07-01-2025, 01:58 PM
Stan, Question regarding the cam you're using since i'm not good at interpreting cam card info. Are you using that in a street cruiser? If so, how is the idle quality and vacuum?
Thanks, TJ
  #531
Old 08-14-2025, 10:51 AM
tj.brewster,
Sorry didn’t see your question earlier. The cam Lee came up with for me was to keep it totally stock sounding and maintain factory vacuum while increasing reliability and power. I am also using the stock exhaust manifolds and exhaust. It will appear 100% original on the outside.
Any other questions feel free to PM or post here.
Thanks,
Stuart “Stan” Landreth.
Also, we scrounged up all the material that we had here and made what is most likely the says sets. I have sold most of them. I think I’m down to 5 or 6 sets left.
The Following 2 Users Say Thank You to Stan65 For This Useful Post:
  #532
Old 09-03-2025, 10:44 PM
P@blo's Avatar
Looks like the Comp Cams 31-1000 part number has been discontinued and is no longer available. The old Comp part has been replaced by the same made in the USA product, like Bruce Springsteen, Howards 90142 for those that want to know.
Probably from the same place as the Comp looks the same.
  #533
Old 10-11-2025, 04:27 PM
P@blo,
Thanks for the update on the Ford spider for the guys that want to use that approach instead of the bolt in system.
That being said, I have several sets of the dog bones left.
I also have 2 sets of USA made sealed power HT2148 lifters for sale to complete the “kit”
Thanks for all the support!
ID:	658556   Click image for larger version
ID:	658557   Click image for larger version
  #534
Old 11-16-2025, 03:18 PM
All,
I have 7 sets of the bones left, and one set of USA made Sealed Power HT-2148 lifters.
Thanks,
  #535
Old 11-28-2025, 09:46 AM
All,
Have 5 sets of bones (retainers) left. Will not be making more without preorders in a quite large quantity. The pricing has skyrocketed on the materials.
Lifter are all sold.
And a big thanks to all that have purchased and are running them now.
That’s 142 sets not including the 4 sets I have set aside for me out there!
On to the next big idea.
Thanks all,
The Following 7 Users Say Thank You to Stan65 For This Useful Post:
  #536
Old 12-02-2025, 05:28 PM
Originally Posted by 67Lemons View Post
I reached out to Butler for a cam recommendation on my potential build. It’s a 455 with TRW/Sealed Power flat tops, 7K3 heads with exhaust manifolds & 2.5” exhaust. The car is a ‘72 GTO with an M20 & 3:23 rear gear, basic street cruiser, no race, blah blah blah. They came back with a recommendation on the Butler with 112 lobe separation. Obviously they don’t know anything about running this lifter set up & I’d have to make sure with measurements that it will work but what’s everyone think of the cam recommendation? I’m not sure I have enough compression to run it but Butler said no problem.
https://butlerperformance.com/i-3164...tegory:1459686
I have about the same specs in my 70 TA. Please let me know how this cam works out for you.
The Following User Says Thank You to tj.brewster For This Useful Post:
  #537
Old 12-12-2025, 08:47 PM
Down to 4 sets get them while you can!
  #538
Old 12-19-2025, 02:33 PM
69gtocv 69gtocv is offline
PM sent
  #539
Old 12-21-2025, 12:56 PM
69gtocv,
Message replied. Thanks for the purchase.
3 sets left!
  #540
Old 12-23-2025, 12:23 PM
FinGTO FinGTO is offline
69gtocv,
3 sets left!
PM sent
