Old 06-26-2025, 08:27 PM
Rachelsdad's Avatar
Question '62-'63 Backup light lens gasket source
Hi, all...
In the process of changing a burned out bulb, I discovered that while my backup light lenses may be a little dirty (and NOS ones are available on eBay), the gaskets are dirty and hard as a rock (no surprise).
It seems that there are several sources for parking light lens gaskets, and OPGI even has the license plate light lens gasket of the same material (white foam), however, nobody seems to have the silly round ones with the screw hole loops for the '62 and '63.
The factory part number is apparently 5953211, and should fit all full size models for both years.
I have solid ones for making templates, too, if anyone happens to have a source for that 1/8" - 1/4" white foam (assuming it can be cut with normal tools vs having to be stamped).
TIA
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
POCI #3596 (since 1978)
Old 06-29-2025, 03:08 PM
Redpiston Redpiston is offline
I had same issue with front turn lens on my 66 2+2. I found some material at grainger that was similar foam with high heat properties. and made them
The Following User Says Thank You to Redpiston For This Useful Post:
Old 06-29-2025, 05:31 PM
misterp266's Avatar
Default Gasket material
I’m interested as well to make ‘63 taillight lease gaskets. Do you have a pn for the grainger stuff?
For my bu lights, I found some silicon gaskets on Amazon that were close and made them work. I have more if you want them. LMK
" Darksiders Rule "
Old 07-03-2025, 09:51 PM
Rachelsdad's Avatar
Sorry for the later than expected reply, and thanks, guys.
There is a listing on eBay right now for lenses and gaskets which supposedly fit both Tempest & full size, '61-'66. I'm skeptical, as I know the backup lights were considerably different between them. I may order them just to check out the gaskets, or ask for some measurements.
I'll let you both know how I make out, and then we can discuss the silicone option and the Grainger foam option if need be.
As for the inner tail light lens gaskets (white ones), I thought I might have had an extra set. I know I have a few NOS bezel-to-body gaskets (black). Let me have a look-see at the end of next week when I'm back home, and I'll follow up.
Cheers, and Happy 4th!
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
Old 07-04-2025, 10:41 PM
I just got back from vacation. I'll look for my roll of material I used for my gaskets.
Old 07-05-2025, 08:55 PM
I found the information on the material I purchased from Grainger. It is now discontinued. I only bought a 12x12 piece. Wish I would have bought more now. As I recall it was pricey. I think it cost me around $42. The material is white silicone foam for food industry and was 3/16 thick and was good from -67 to 392 degrees. The package had a Marian Chicago Inc label on it. The numbers on the package was BF1000 and 20Y093.
Attached is Grainger site snip.
I also attached a possible alternative. Its good -80 to 450 degrees. I would probably go with the 60 durometer material.
Old 07-06-2025, 12:03 PM
Rachelsdad's Avatar
Great info; thanks.
I'll let you know which direction I take and how I make out.
Cheers
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
Old 07-24-2025, 05:50 PM
Rachelsdad's Avatar
Progress of a sort!
I contacted Rubber the Right Way (http://www.rubbertherightway.com/), and asked if they would be willing to reproduce these given a usable template (they also offer flat material in varying thicknesses, so making my own from their stock would also have been a possibility). Robert got right back to me, and asked me to send a housing and an existing gasket. They would be happy to add these to their catalog, it seems. Turnaround is approx 4 weeks.
I just so happen to have a spare pair of backup lights complete with gaskets lenses and bulbs, so I will be sending one off to them at the beginning of next week, when I'm back home from this trip.
Sometimes, you just live right, I guess. :-)
I'll update the thread as we move through this process.
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
Old 11-16-2025, 09:16 PM
Rachelsdad's Avatar
A BIG shout out to Robert at Rubber the Right Way (http://www.rubbertherightway.com/) for the excellent job on these new backup lamp gaskets. In fact, they even include (now) the black lamp housing to bumper gasket. P/N 06-279P. They look, feel, and fit great!
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
The Following 2 Users Say Thank You to Rachelsdad For This Useful Post:
