Old 08-25-2025, 07:13 PM
JEC3039 JEC3039 is offline
Default Bolt-on Timing Scale Question
For the front covers without cast-in timing marks, does anyone know the part number of the bolt-on timing scale stamping?
I believe the front cover p/n is 526984, but what's the p/n for the bolt-on timing tab? Thanks.
Old 08-25-2025, 08:42 PM
I can't remember the number, at the moment.
EDIT: Found this # but not sure if correct?
527065
But the crank damper/hub for the timing cover is a small hub basically. (solid)
You have that?
Old 08-25-2025, 09:51 PM
Yes, we have the hub. Just need the plastic timing tab.
