Old 09-13-2025, 03:00 PM
form74's Avatar
form74 form74 is offline
Default What shocks for a street car
The 75 I picked up needs new shocks.
The car will be street driven, taken to cruises and car shows
Link to the 75
https://forums.maxperformanceinc.com...d.php?t=881563
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 09-13-2025, 10:02 PM
Maxthe222 Maxthe222 is offline
I love the Koni adjustables, but the Bilstein's are also pretty good and a bit more affordable.
1987 GTA L98
1981 Y85
1979 Y84/WS6/Z49
1979 VSE F/A W72/4+1
1978 Macho #46
1978 W50/L80
1972 WS4 Lucerne Blue
1971 W66/M20/L78
Old 09-14-2025, 09:05 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
If you want a more factory ride the KYB Excel-G, Monroe blue gas shocks, would be a good choice. If you want a bit harsher but better cornering Koni, KYB Gas Adjust would be good
Old 10-13-2025, 08:29 AM
MDSHARK81 MDSHARK81 is offline
I have Bilsteins on my 71 TA, not harsh at all, but handle very well, better than stock!
Old 06-19-2026, 08:53 AM
form74's Avatar
Finally replaced the shocks , went with the KYB Gas adjust
The old ones were not original but were made in the USA and were all shot none of them would rebound after compressing them , not sure when they were changed last.
Car handles so much better and doesn’t push threw the corners anymore
Next upgrade will be replacing all the bushings and front end parts.
ID:	672072   Click image for larger version
ID:	672073   Click image for larger version
ID:	672074   Click image for larger version
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
The Following User Says Thank You to form74 For This Useful Post:
Old 06-19-2026, 09:58 AM
rwfisher's Avatar
rwfisher rwfisher is offline
While they do look old enough that it was time for replacement they appear to be hydraulic shock so they would not have any rebound even when new. . .
The Following User Says Thank You to rwfisher For This Useful Post:
