Old 10-23-2025, 09:29 AM
Qball's Avatar
Qball Qball is offline
Default Check out my new paper weight....
I dropped a valve a couple months ago and finally got to pulling the engine and tearing it down to have the block assessed. Good times!
ID:	659181   Click image for larger version
ID:	659182   Click image for larger version
ID:	659183   Click image for larger version
ID:	659184   Click image for larger version
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry!
- Mike
1967 GTO
The Following User Says Thank You to Qball For This Useful Post:
Old 10-23-2025, 09:36 AM
Formulas's Avatar
Formulas Formulas is offline
Duuuude nice paper weight.. What was the valve situation thesis of breakage?
Old 10-23-2025, 10:03 AM
Qball's Avatar
The best theory I can come up with is that the keeper failed. The ledges seem to be sheared off.
ID:	659194   Click image for larger version
ID:	659195   Click image for larger version
ID:	659196   Click image for larger version
ID:	659197   Click image for larger version
- Mike
1967 GTO
Old 10-23-2025, 10:12 AM
Formulas's Avatar
Do you recall source of the keeper, Apparently it was lacking some strength
Old 10-23-2025, 10:31 AM
Qball's Avatar
No. A friend of mine built the heads. He sourced everything. He's an excellent machinist/engine builder. I think this was just bad luck.
- Mike
1967 GTO
Old 10-23-2025, 11:10 AM
1969GTO's Avatar
1969GTO 1969GTO is offline
Looks like one of those awards from a local car show
color me gone
Old 10-23-2025, 11:14 AM
Bill Hanlon's Avatar
A little JB Weld and it'll be good as new.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 10-23-2025, 11:47 AM
What do the other valve stems look like on ones that did not drop?
Old 10-23-2025, 12:21 PM
Those look like factory type replacement valves, head could have come off.
Old 10-23-2025, 01:34 PM
Qball's Avatar
Not sure. I haven't disassembled the heads yet. They were 6X heads and I'll probably be moving to an aluminum set when things start moving.
- Mike
1967 GTO
Old 10-23-2025, 01:38 PM
Qball's Avatar
This is the valve in question.
- Mike
1967 GTO
Old 10-23-2025, 02:10 PM
Yeah that looks like the common failure point for the OE valves.
Can you look on the paperwork and see if the valves were replaced, and a part number?
Old 10-23-2025, 02:40 PM
Qball's Avatar
I just texted him. They were stainless aftermarket valves.
- Mike
1967 GTO
Old 10-23-2025, 05:19 PM
Guessing the dynamics:
Head falls off, valve stem popps-up, rocker/ pushrod displace, Keepers fall out of retainer, valvestem goes down into CYL for chomping.
Old 10-23-2025, 05:46 PM
Yeah if they were SS valves, then it was either keepers, retainers, maybe rocker contact on retainer, etc.
Bummer. Sorry to hear about this by the way...
Old 10-23-2025, 06:20 PM
That retainer in that first photo has witness marks that looks like the rocker arm started to ride on it.
That would have compressed the spring and then released it which would have hammered the lock and failed it.
I don’t know that any grade of keeper could take that kind of pounding for long.
That roller tip sweep pattern on the top of those keepers is hard to explain.
Do I see that a jam nut was used to adjust those rocker arms?
What rpm did this mayhem take place at?
Old 10-23-2025, 06:48 PM
Qball's Avatar
Yes, a jam nut was used to adjust the rockers.
it happened around 12-1500 RPM. It was in my garage.
My theory is (and I could be way off base), the keeper started to give way and the valve stem started to sink and that allowed the rocker to make contact with the retainer. Then the keeper finally let go and the valve dropped fully in.
If you look at the pics of the keeper, it looks like the ledges that hold the valve up are sheared off.
- Mike
1967 GTO
The Following 2 Users Say Thank You to Qball For This Useful Post:
Old 10-23-2025, 10:08 PM
NeighborsComplaint's Avatar
Good eye.
Rocker/retainer interference from short pushrods can do that. The rocker becomes a valve spring compressor, out come the keepers and then pop goes the weasel.
Check for interference especially if the keepers look fine.
Triple Black 1971 GTO
Old 10-24-2025, 07:41 AM
Formulas's Avatar
Understand what you guys are saying about rocker contact but if a lock goes south slowly because of bad heat treating the keeper will gain installed height then conceivably touch rocker as well..... So it comes down to which spot exhibits more wear time before total carnage and that's where it all started
Old 10-25-2025, 02:28 PM
Pontiac Performance Author
what does the rocker sweep pattern lock like on the other valves?
The Following User Says Thank You to KEN CROCIE For This Useful Post:
