Old 11-02-2025, 06:01 PM
64 GTO frame off in NY at $44K.
https://www.ebay.com/itm/12746674791...Bk9SR-i4munIZg
  #5902
Old 11-03-2025, 12:11 AM
On the Red 67 GP Vert
The pwr vent windows are extremely rare , and underhood reel out light also a rarity.
The 400 4bbl engine had 2 variations that year.
This one looks to be the 670 heads with QJet version. Same as 67 GTO
The other version had 061 heads and AFB carb.
I think it was an Early vs. Late factor on those engines.
The 061 heads were 2nd design premium fuel cylinder heads used on full size cars on both 2 barrel and 4 barrel motors but they were not used on Grand Prixs. The GP did use 670 heads but the 10.5 cr version on the 400 and 360hp 428. The 428 HO used the same 10.75 cr 670 heads as the GTO. The 400 engines all came with the AFB and the 428 had the QJ . I have 3 67 Grand Prixs with the 400 engine and all have the 670 heads with AFB. I also have a 1967 Catalina with the 290 HP 2 barrel motor that has the 061 2nd design premium fuel cylinder heads. The manifold in the photo looks like a QJ manifold but if it is original the engine should be a 428.
  #5903
Old 11-03-2025, 01:06 AM
I've had two 67 GP 400 engines that I pulled from the cars. Code XJ iirc
One was 061 heads and AFB
Other was 670 heads with QJet
This was mid and late 1980s
The window sticker on the car indicates 400 engine and no 428 emblems present.
All I could ID in the pictures were the 670 heads and QJet intake
But it could be anything in it.
  #5904
Old 11-03-2025, 01:17 AM
Yes, hard to know what the car came with this many years down the road. I just know what I have observed personally and what the MPC shows. XJ code should have the 10.5 cr 670 heads according to the parts book.
  #5905
Old 11-03-2025, 01:20 AM
I use the same method.
Those books don't always tell us right every time.
I had buyers for 061 heads after the HPP flow test articles, and kept a look out for them.
Only ever had that one set on the XJ engine.
73-74 #46 heads with screw in studs from 350 engines got popular after those articles too.
  #5906
Old 11-03-2025, 09:37 PM
Are 061 heads worth anything these days? I always thought they were not high performance because they weren't the 067's. I believe both are closed chamber. Is the difference the same as a #13, #12, #62, #48 heads, or maybe the 68 #16's?
  #5907
Old 11-06-2025, 09:16 PM
68 Firebird in Connecticut at $40K BIN. Prolly lots of mud in the rear flipper. Not many pics and none of the dash.
https://www.ebay.com/itm/14694566644...Bk9SR8KP4b3LZg
  #5908
Old 11-06-2025, 10:42 PM
And now for something completely different, 1953 Pontiac Chieftain Sedan Delivery in Indiana for $30K BIN. Cool car.
https://www.ebay.com/itm/14694585089...Bk9SR6iC_cHLZg
  #5909
Old 11-07-2025, 11:12 PM
Wow! 79 Firebird Formula with 27K miles at $25K BIN in Ohio.
https://www.ebay.com/itm/22706445796...Bk9SR6ST8ZbMZg
  #5910
Old 11-08-2025, 10:51 AM
Interesting build sheet on this 74 GTO sold in Canada. Bench seat 4 speed, but the build sheet says it's an automatic? $43K in Michigan with 64K miles.
https://www.ebay.com/itm/39721944631...Bk9SR4iPxr7MZg
  #5911
Old 11-08-2025, 05:09 PM
Nice 74 GTO, interesting that it had a vinyl top. Too bad about the black window moldings.
Old 11-08-2025, 06:28 PM
Cammer-6 Cammer-6 is offline
nice 74 but how did that subframe get so beat up?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #5913
Old 11-08-2025, 06:43 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
The center section of the subframe isn't supported on the inside so when you use it as a jacking joint, it bends like shown. I've corrected several of them over the years by cutting it out, straightening it in a press and welding it back in.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
The Following User Says Thank You to RAJ7395 For This Useful Post:
  #5914
Old 11-08-2025, 07:47 PM
Never heard of the Willow Run plant in Michigan before. That's interesting.
Have a 74 GTO 4spd #s car that turned into a parts car after a falling tree accident.
No idea where it was built.
  #5915
Old 11-08-2025, 08:04 PM
They had good flow numbers for D-Port .
Home porters and home builders wanted them.
They didn't bring as much as 67-72 screw-in stud D-ports , but they weren't even sellable at all before the HPP articles.
Going rate would have been 150-200pr .
250-300pr for 67-72 screw-in stud heads. Back then.
1970 intakes got popular , and #46 350cid heads -also- after the articles.
There aren't anywhere near as many hands-on guys now as there were back then.
Paying to port or fully rebuild cast iron heads now is a diminishing return compared to box stock aluminum heads for non-numbers cars.
  #5916
Old 11-09-2025, 12:34 AM
Thanks. I have a set of 061 heads I was going to toss. Shipping them may cost more than they're worth.
  #5917
Old 11-09-2025, 12:39 AM
75 Trans AM 4-speed in Ohio at $11K NR. Says it's Buccaneer Red, but it looks a little orange. Prolly a good buff out on the paint would bring it back. Ad also says it runs and has a rebuilt 400. A set of 15" honeycombs on this car would up its value. I'm not sure what impact taking the picture in a parking lot full of fresh burnouts makes. Does it scream the car is fast, or the owner beats the crap out it?
https://www.ebay.com/itm/35787696161...Bk9SR7zGt-3MZg
  #5918
Old 11-09-2025, 11:16 AM
69 GTO in Michigan at $26K BIN. Silver with a green interior, it was originally a Limelight green car, which is a very cool color combo. Poor pics in the ad.
https://www.ebay.com/itm/31746765806...Bk9SR7iy3pLNZg
  #5919
Old 11-09-2025, 08:51 PM
Some projects are much harder than others. I would call this one difficult with a lot of good parts. 81 Trans AM in Texas at $500 NR. Chevy 454 with a 4-speed.
https://www.ebay.com/itm/30659314845...Bk9SR8rqv7PNZg
  #5920
Old 11-09-2025, 08:59 PM
68 Firebird convertible in NY at $65K. Nice car, but $65K buys a lot more than this car. The little stuff stands out, like the unpainted hood tach. The original 350 engine was an odd choice to build up that much. I removed the 350 in mine and installed a 400.
https://www.ebay.com/itm/15745284698...Bk9SR8rqv7PNZg
