Old 11-24-2025, 06:34 PM
Bcwoods Bcwoods is offline
Default Rear shock mounts second Gen
Hello all, when welding in the rear shock mounts, they are just welded to the rear seat/trunk flange? Or does this middle filler panel needs to be included. It's to far inside which creates a gap...
Old 11-24-2025, 07:58 PM
unruhjonny's Avatar
Does this image help you?
1970 Formula 400
Old 11-26-2025, 02:26 PM
Just did this recently on my 70. I drilled through the shock tower into the sheet metal brace behind and used screws to pull everything together, then welded the 4 factory holes. Then welded the screw holes shut after. Also welded to the trunk floor at the green dots, same on the forward side
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
