Old 12-05-2025, 10:40 PM
Mike S's Avatar
Mike S Mike S is offline
Default Parts washer fluid?
What are you guys putting in your parts washer? Need a good strong cleaning fluid.
Old 12-06-2025, 01:39 AM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Tractor Supply PSC 1000
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
The Following 2 Users Say Thank You to hojs69 For This Useful Post:
Old 12-06-2025, 06:46 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
X2.
Old 12-06-2025, 09:07 AM
Half-Inch Stud Half-Inch Stud is online now
Gasoline and right-sized buckets.
Old 12-06-2025, 10:48 AM
Skidmark's Avatar
Skidmark Skidmark is offline
Originally Posted by Reasejr View Post
Choosing the right fluid for a parts washer really depends on your machine type, what materials you are cleaning, and your workshop environment. 'Strong' can mean different things, but safety should always be the top priority.
I would recommend Aqueous.
AI?
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
The Following 2 Users Say Thank You to Skidmark For This Useful Post:
Old 12-06-2025, 10:59 AM
tekheavy's Avatar
tekheavy tekheavy is offline
Spray Nine.
Old 12-06-2025, 11:23 AM
Elarson's Avatar
Elarson Elarson is offline
x3
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 12-06-2025, 01:09 PM
bdk1976 bdk1976 is offline
I've always used solvent (PSC1000 in recent years) in my harbor freight parts washer. Inherited a second HF unit a while back and filled it with slightly diluted purple power concentrate (cheaper but not as effective).
The PSC1000 works better - by far - and also safer when it comes to aluminum, etc. I generally only use the purple power for soaking/prewashing really filthy steel parts and often do a final touchup/rinse in the solvent.
Over the years I've also snagged some half empty cans of mineral spirits at garage/estate sales for cheap/free and dump them into the solvent tank to top them off.
The Following User Says Thank You to bdk1976 For This Useful Post:
Old 12-07-2025, 07:18 AM
JSchmitz's Avatar
For cleaning parts outside, try Dawn Powerwash. Great stuff!!!
Old 12-07-2025, 09:33 AM
Fun faxt: pistons soaked in gasoline overnight will let the carbon deposits brush off with ease.
Old 12-07-2025, 10:23 AM
BB70's Avatar
BB70 BB70 is offline
Had good luck in a HF parts cleaner with stoddard fluid.
Old 12-07-2025, 11:19 AM
Held for Ransom's Avatar
Only if they come with the correct pump. Most fail because they use the wrong solvent/cleaner.
So long, farewell.
Old 12-08-2025, 11:58 PM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Originally Posted by Elarson View Post
x3
Eric
X4!
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 12-09-2025, 11:25 PM
RocktimusPryme's Avatar
I have a Jegs parts cleaner which is probably the exact same unit as the harbor freight one. Ill X5 the Tractor Supply stuff.
To me it was the best blend of, cost and safety for a solvent based material. Gasoline probably works better for cheaper.......but I dont have the best spark dicipline in the world when Im working. So I didnt want to have a source of gas vapor floating around.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 12-14-2025, 04:07 PM
lust4speed's Avatar
Good solvent destroys the pumps I've tried. Anyone found a pump that will last and not fail?
Mick Batson
Old 12-14-2025, 06:12 PM
hojs69's Avatar
Little Giant 51855, used for many years with PSC 1000.
See link: https://www.amazon.com/Little-Giant-...iglink27338-20. Ignore price, can be found much cheaper.
I also put a recirculation filter, drains, etc.... on my cheapy HF washer. Works great.
Name:	parts cleaner (3).jpg
ID:	662178   Click image for larger version
Name:	parts cleaner (2).jpg
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
The Following User Says Thank You to hojs69 For This Useful Post:
