Old 12-25-2025, 05:46 PM
CatalinaMike CatalinaMike is offline
Default 81 wiring harness
Couldn't find an answer yet so here goes. Have an 81 TA which has no wiring worth keeping. The emissions and computer are gone so not needed for that Can I use a 77-80 harness for plug and play? Thanks
Old 12-26-2025, 10:23 AM
78w72 78w72 is offline
77-80 should fit into the firewall bulkhead connector with all the critical wires being the same... but worth double checking a wire diagram or comparing to the 81 harness pins/wires.
Old 12-27-2025, 05:40 PM
MO Olds MO Olds is offline
80 and 81 are blade fuses on inside bulkhead connector but as suggested may be the same wire location. I have a perfect condition dash harness from an 81 I would sell if you want to reach out.
