Old 01-02-2026, 01:22 AM
JEC3039 JEC3039 is offline
Default 78 TA Y82 W72 Automatic - carb solenoid stop - yes or no?
Were the W72 automatic cars equipped with carb idle stop solenoids?
Old 01-02-2026, 11:15 AM
burd burd is offline
Yep.
Should have a green/ black wire in the harness.
Look at your emission label, it shows rpm to set it.
Old 01-02-2026, 12:24 PM
Think that was 'idle up' for when the AC was turned on.
Clay
Old 01-02-2026, 01:14 PM
There’s a small decal on there too.
Old 01-02-2026, 04:24 PM
The reason I'm asking is that I just installed a new engine wiring harness from AAW but there is no green/black wire for the solenoid.
I know how it should be - as I recently installed an AAW harness in my '68 Firebird 400 automatic car and the green/black wire with proper connector WAS provided in that harness.
I'll give AAW a call.
Old 01-03-2026, 09:28 AM
Kenth's Avatar
Kenth Kenth is offline
Yes.
Name:	1978 idle speed settingd.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-03-2026, 05:07 PM
Kenth - thanks for this. I think it clears up the situation.
My car is a factory "non-A/C" car, which is actually rarer than the A/C cars since most customers were ordering A/C by 1978. So my build is like pic 16. Pic 17 speaks to A/C and shows the solenoid.
When you order the wiring harnesses from AAW, the non-A/C harness is a different p/n than the with A/C harness, so perhaps those folks knew not to include the green/black solenoid feed wire with a non-A/C harness.
What got this whole thing going with me is that my Quadrajet (original to the car) is drilled and tapped at the left front corner for mounting a solenoid, but there's no solenoid present. I wasn't sure if it simply got discarded over the last 50 years or if it wasn't ever present to begin with. It's not like GM to take the time to drill and tap some feature if they're not going to use it, so I was confused, but perhaps GM drilled and tapped them all in that era for simplicity.
I'm going to proceed with my build without adding a solenoid at this time. I'll look at other non-A/C cars this summer at shows and see what others have.
Old 01-04-2026, 11:27 AM
None of the 78’s are rare. Rare VS a cheap person ordering a new car
Old 01-04-2026, 05:47 PM
Poncho Dave Poncho Dave is offline
All carbs are drilled and tapped for solenoid mounting in case it was required for use.
Old 01-04-2026, 11:27 PM
Thanks Dave
Old 01-05-2026, 11:33 AM
Not all, got a bud who can’t put one on his ta, no holes to mount the brkt.
