I've searched this site using all different search terms and couldn't find these dimensions.
Is this the correct drawing for a mid 70's Pontiac block?
69 Firebird Conv, 350 HO w/3 on the tree swapped to Tremec 5 Speed - Sold 72 GP, 400 Auto - Sold 09 G8 GXP M6 Orig Owner - Sold 76 Trans Am 455, 4 Speed - Current |
Are they calling out bellhousing bolts as 5/16-18? I'd have expected 3/8-16.
Other than that, that seems to be all correct for the bellhousing bolt pattern. Not sure about the flywheel bolt patterns. |
That’s anything but a Pontiac block.
The dimensions are different that they give and besides that look at the 4 water jacket frost plugs seen behind the flywheel. Pontiacs only have two on each side and there higher up.
The casting about the 7.07 dimension doesn't look right. I think it be smoother angle and no lip. Could be Buick or Olds.
Even if it was a B or Olds block the bell housing bolt holes would be 3/8” .
This is from Gavin (I believe) :
I just cut a fixture last month utilizing these holes and can verify them to be true.... so I assume the top ones are too.
Kris. |
| The Following User Says Thank You to RUDOLFSSON For This Useful Post: | ||
