Old 01-17-2026, 09:26 PM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default 74 Master Cylinder
Is a CS master cyl correct for a 74 T/A with PDB? If so I`m looking for one.
Thanks KC
Old 01-20-2026, 09:47 PM
Nobuddy Nobuddy is offline
Where are they stamped?" I have mine soaking for a rebuild and can check in the morning.
Old 01-20-2026, 11:20 PM
Held for Ransom's Avatar
Yes, they are. Here is one on a 12K original, read CS (application) 4 (year) and 198 (July 17th, Julian date)
So long, farewell.
Old 01-21-2026, 09:09 PM
Same on mine except one day newer. Also the casting numbers if that helps.
Name:	74 Master Cylinder Stamp.jpg
ID:	663995   Click image for larger version
Name:	74 Master Cylinder Casting.jpg
Old 01-24-2026, 09:29 AM
Thanks, HFR is that master stamped on the front pad also? And does it have bleeders?
Old 01-24-2026, 12:09 PM
It is, more or less, the front pad. They had the pad for bleeders, just no bleeder. This one is June 27th, 1974.
ID:	664102   Click image for larger version
So long, farewell.
Old 01-24-2026, 01:02 PM
This one is stamped a little different with the cs last so it`s either 319 day of 70 or 190 day of 73 and it has bleeders. Thanks for your help.
Old 01-24-2026, 02:01 PM
Yup, July 9th, 1973.
This one is June 14th, 1973. 3165CS. Bleeders.
So long, farewell.
Old 01-24-2026, 03:11 PM
Here is the one from my Oct. '73 built '74.
Sept. 10th, 1973. CS3253.
So long, farewell.
Old 01-24-2026, 05:59 PM
So, when did they start with the small stamping with the Julian date by the bleeders instead of the larger 2 letter code stamped on the front machined pad?
Old 01-24-2026, 11:18 PM
I would say 1973 model year, for sure. Maybe 1972, but it would have been the end right before the strike.
So long, farewell.
