Old 03-21-2026, 10:52 PM
grivera's Avatar
grivera grivera is offline
Default Vent for 12 Bolt Rear
My 66 Lemans has a 12 Bolt rear from 66 Chevelle. The vent hole is in the center section and smaller than 3/8”. The vent tubes I’ve found all say for 3/8” hole. They all look the like the one Inline Tube sells, advertised as 64-81 Chevelle for 3/8” axle hole, and when I enter the make and model information, it says it won’t fit. Where do I find one that fits?
https://ebay.us/m/9aymTa
Will Rivera
Old 03-21-2026, 11:34 PM
Held for Ransom's Avatar
Original part number was 3820840.
So long, farewell.
Old 03-22-2026, 07:58 AM
grivera's Avatar
Thank you- will give that a shot
Will Rivera
Old 03-22-2026, 02:21 PM
Kenth's Avatar
Kenth Kenth is offline
Check these:
https://www.firebirdcentral.com/Fire...nnmLQCDJyrfQgM
http://www.nitemareperformance.com/1...breathers.html
https://www.summitracing.com/parts/opg-c220128
https://www.summitracing.com/parts/oer-15771000
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-22-2026, 03:50 PM
sdbob sdbob is offline
I read on line the size is id is.375. Dorman makes one try local parts store. Also measure your hole, might be tight .375. I googled 12 bolt . 312 vent. Was talked about.
Old 03-27-2026, 10:45 AM
grivera's Avatar
Thanks- all of these are 3/8 and the hole is 5/16 (.312). I tried one of 3/8 variety for S&G and confirmed.
The .312" valve is what I need but apparently, it's constructed of unobtanium
Will Rivera
Old 03-27-2026, 03:30 PM
400 Lemans's Avatar
This one might work for you.https://torqueking.com/products/3004...4NJ2eqcB1EtT2q
Old 03-27-2026, 04:38 PM
grivera's Avatar
Thanks - just ordered! Hope it fits cause shipping was a big kick in the cojones!
Will Rivera
Old 04-29-2026, 01:32 PM
If ever in need of a new vent for a corporate 8.5 this is the one I bought for my ‘71 Olds 8.5 rear.
Part #1236317
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 04-29-2026, 02:22 PM
grivera's Avatar
Originally Posted by 400 Lemans View Post
I made the Tork King one work - had to sand it down some for a fully seated and snug fit, and used RTV to make sure it's sealed.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
