Old 03-24-2026, 10:45 PM
SRGN SRGN is offline
Originally Posted by grivera View Post
Maybe a long shot but did installer forget to put anaerobic sealer between rear main and block?
Great advice here. I've used anaerobic for years on rear mains in my Buick builds. I also use it between the 2 halves of the neoprene rear main seal that I use instead of the rope seal. I haven't had a rear main leak since I started doing it that way. Far superior to silicone.
  #42
Old 03-25-2026, 04:24 AM
If you did not install the seal yourself I wonder if it was installed not facing the right way.
Many seals are made such that they need some crankcase pressure to load the sealing lip onto the crank .
