Old 03-29-2026, 08:28 AM
Default FMG Cold Case E-Fan Shrouds and Skid plates
Has anyone tried the FMG E-Fan shrouds for Cold Case rads?
They look nice, and are made to specifically use certain dual 14" fans, has psi relief provisions, and make one that is compatible with surface mount fans.
https://fastmontysgarage.com/collect...ld-case-shroud
FMG also has a YouTube channel where the guy tests e-fan flows, free-air and mounted.
https://www.youtube.com/@FastMonty
Results are on the main website here:
https://fastmontysgarage.com/pages/fan-cfm-test-data
Also, FMG makes skid plates for classics, that protect the oil pan & crossmember, and 'bat wings' that protect headers.
https://fastmontysgarage.com/collect...pan-protection
Would like to have some real-world data from someone who uses these before I pull the trigger.
Old 03-29-2026, 10:12 AM
JLMounce JLMounce is offline
I talked with Mike about them for a bit, but haven't pulled the trigger yet. I'm thinking about changing my big block cold case radiator for an LS version to gain the added efficiency of a dual pass radiator, then going with his 12" shroud.
I'm not running into cooling issues right now, so it's kind of a want only expense for me currently.
-Jason
1969 Pontiac Firebird
Old 03-29-2026, 10:30 AM
ta man ta man is offline
I'm using a Derale Shroud with twin Spal fans 4000cfm and a cold case rad. I recently switched to electric fans mainly for hp loss not for cooling. I had zero issues with a stock 80 maxi 3 core AC rad clutch fan and shroud. I was rather disappointed with the Cold Case rad..fit wise it wasn't great and made in China.
Old 03-29-2026, 04:21 PM
FMG did a test of the Flex-a-lite brushless fan against the SPAL brushed fan and they were close to identical, with the Flex-A-Lite have an advantage in not only cfm, but the fact it was brushless too.
EDIT: The Flex-A-Lite brushless is half the cost of the SPAL brushless too.
https://www.youtube.com/watch?v=UQiJAYsLgd4
His shroud allows for the use of 14" fans where most only use 12" fans.
I thought the dual pass LS fans had narrower tubes? If that's so, then the wider tubes will win out.
I'm not having issues with the dual 12" Derale setup I use in both the 442 & GTO, BUT, the GTO does run a little warmer, and it certain demand situations does creep temps (like when AC is on). It's about a 10 degree diff.
Going to dual 14" fans would solve that issue on the GTO, and believe the diff is additional displacement (495ci vs 535ci) between it and the 442.
I don't have a space issue, but the brushless fans are around an inch lower depth/height. Could make belt changes etc more comfy.
Old 03-29-2026, 04:29 PM
Dragncar Dragncar is online now
How did that work out ? Was there any power found at the track ?
I have no issues with a stock 3 core and flex fan with a filled block.
But, I do run 2 classes when I race and go a lot of passes on a good day so I bought a Derail 4000 cfm duel fans, Meziere water pump, setup and a big aluminum 2 core radiator so I can cool between rounds. Also bought a solar battery deal so I can run a charger without having to listen to a generator in my pit. Can't stand those things.
There is some controversy about any seen power difference being a wash because the alternator just pulls harder on the belts.
Still have the belt driven stuff in the car and probably will have it all season.
Old 03-30-2026, 10:42 AM
At least on the First Gen F-Body radiators, they state the LS version still has 1.25" tubes.
-Jason
The Following 2 Users Say Thank You to JLMounce For This Useful Post:
Old 03-30-2026, 08:01 PM
Gator67's Avatar
Gator67 Gator67 is offline
We're running 2 12" Spal brushless fans in a Derale Shroud in front of a LS swap Cold Case radiator in my son's 79 TA. It works perfectly, the engine stays at the temp we set in the Terminator X software regardless of the temps outside, A/C in use, etc. We could have also set up the fans using their proprietary temp sensor/switch, but there's more controllability through the EFI software. The Spal brushless fans sit inside the shroud somewhat, so if you're interested in going in that direction, you'd need to make sure FMG fans are thick enough. Also, we experimented with 14" brushed fans in a modified cold case shroud, but there was interference with the steering box. We could have made some other changes to make it work but it didn't keep the car as cool as we wanted so we bagged it. I suspect his shrouds take the width needed into account, but may want to double check.
The Following 2 Users Say Thank You to Gator67 For This Useful Post:
Old 03-30-2026, 09:23 PM
Mike originally designed his shrouds around SPAL units and addresses that directly.
https://www.youtube.com/watch?v=IeKLbAKBMtc
-Jason
Old 03-31-2026, 07:14 AM
Still to be determined if it has picked up.
Old 03-31-2026, 10:05 AM
The brushless SPAL fans are so friggin expensive, it's even painful to shop them. And the SPAL brushed fans are about the cost of other brushless offerings.
Some of that though is due to the electronics, many brushless fans have a 'simple' PWM controller built in. All you need is a programmable PWM output to run them.
Being able to run a pair of 14" fans is certainly an advantage over a pair of 12", and the cost difference between is nominal.
Nice thing about that Flex-A-Lite fan is that it can run either off a voltage signal or a PWM signal. OE replacement type and many other brushless fans require a PWM input, as a reminder.
Overkill with a cooling system is a win-win, it's like that saying about condoms...
Old 03-31-2026, 10:27 AM
Actually, comments I made referencing 'Flex-A-Lite' fans is really the Proform fan that FMG tested....
EDIT: This one:
https://www.summitracing.com/parts/pro-67035
Old 03-31-2026, 03:57 PM
punkin punkin is offline
I'm running a pair of the Proform brushless fans and the FMG shroud. Fitment is very nice.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
Northwind (Induction undetermined)
3.50:1 Rear
The Following User Says Thank You to punkin For This Useful Post:
Old 03-31-2026, 04:38 PM
How loud are those things?
-Jason
Old 03-31-2026, 06:15 PM
Gator67's Avatar
The brushless Spals aren't noisy from a mechanical standpoint, though when they're going full blast you can definitely hear air whooshing. The nice thing is that they start soft and ramp up slowly and run only as fast as needed to keep the engine at the specified temp, so you don't really notice the sound at all unless you're paying attention--kind of like on a modern car.
Old 04-01-2026, 11:02 AM
The ProForm fans have soft-start too.
Blade design has a lot to do with sound, and to move X air, the fans blades need to be X, and will make noise.
That vid FMG did comparing the SPAL to the Proform gives you a pretty good idea of how loud they are, but are comparable to like OE pickup truck fans. When on high.
EDIT: This is the comparison vid: https://www.youtube.com/watch?v=3_GvR8lCJoE
Old 04-02-2026, 01:46 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
They're expensive, but 2000CFM per fan with a load is friggin' impressive, man. I'd pull the trigger on 'em knowing I'd probably never have to worry about low speed or idle cooling issues again, even in the summer with AC running.
I've also seen them on special at the mid $400+ range, not that it's really any better. The investment IMO is a small price to pay to prevent an overheat or the stress of always having to keep my eyes glued on the temp gauge. Like you said, overkill with a cooling system is never a bad thing.
Just sucks that it's not only a matter of getting the fans, though. He recommends 6 AWG wire, which is absurd for a cooling fan, and a 200 amp alternator. Both fans together would be pulling nearly 80 amps if his tests are any indication.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following 2 Users Say Thank You to nUcLeArEnVoY For This Useful Post:
Old 04-02-2026, 10:30 PM
On my previous setup I had a single 16" (If memory serves) which was full speed on or off so it was always loud. I think in comparison at full speed, the proforms are pretty similar but the variable speed really makes a difference when under light heat load.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
3.50:1 Rear
Old 04-02-2026, 10:45 PM
R 70 Judge's Avatar
I have the Derale 16826 fan/shroud kit (dual 12” fans 4000cfm total) on my TA. Cold case radiator and a mezeire HD waterpump. I’m very happy with the setup. 14:1 on pump E85. The fans aren’t overly loud (to me anyway) and it will hold at 170*-180* max in 90+* weather on the street.
Seems to have gone up in price a bit Check out this page from Summit Racing https://www.summitracing.com/parts/d...iaaegj-npd_bwe
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 04-02-2026, 10:51 PM
R 70 Judge's Avatar
Monty makes some nice stuff and I like that he gives real world test results. You probably can’t go wrong with his stuff.
James
1970 Trans Am
Old 04-03-2026, 12:10 AM
Fastmonty's Avatar
Fastmonty Fastmonty is offline
Hey Team... love the comments. Those that don't know, I started with the full ColdCase radiator and fan kit, which I found insufficient. (The Cold Case 14" fans are actually 13") I started testing fans, and discovered that the Brushed 14" Spal, and 14" Proform Brushless have similar performance, and similar price point. I now have over 25 Shroud designs on my website, with new customer reviews weekly.
I will be coming out with a shroud for the Behemoth 14" Brushless SPAL, but as you know it's expensive. In this hobby, almost everything is "You get what you pay for". Finding that balance is the fun part.
As for the previously mentioned comment about the "Skid Plate" I designed for 64 to 72 GM A-Body's, it protects the Oil Pan, not the headers. It has saved my 69 GTO twice since installing it. Just did a video about the skid plate damage here; https://youtu.be/Q0DA63Rofos?si=c-vv8jUBctsGg_Ik
Any other questions, let me know on YouTube or through my website https://www.fastmontysgarage.com/
See ya!
Monty
The Following 2 Users Say Thank You to Fastmonty For This Useful Post:
