Old 03-31-2026, 05:51 PM
Terry M. Hunt Terry M. Hunt is offline
Default Strange cylinder head bolt
The attached photo shows the cylinder head bolt located at the center exhaust port on my 66 GTO with original 093 heads. Just curious why the head of this bolt is made this way. Any ideas?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 03-31-2026, 05:58 PM
I think they had a bulletin on it.
Seems like it was for heat maybe?
(would have to look for it)
I also think it was on some other year(s)?
1967?
Old 03-31-2026, 06:19 PM
To help radiate heat away from the siamesed exhaust ports? Would love to see that bulletin. Interesting theory.
Terry Hunt
Old 03-31-2026, 06:40 PM
I have this:
Nothing about the heat though. Probably wrong on that.
Old 03-31-2026, 08:15 PM
LStathas LStathas is offline
So Ironic. I came across one while going through some of my bolts and wondered the same thing. If anyone needs a singleton let me know.
Green Bay: A drinking town with a football problem.
Old 03-31-2026, 10:16 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
I’ve only seen this extended head bolt used on 1966.
ID:	667371   Click image for larger version
ID:	667372   Click image for larger version
ID:	667373   Click image for larger version
Name:	1965 GTO Recent 198.jpg
ID:	667374   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 03-31-2026, 11:25 PM
60sstuff's Avatar
I’ll take a single.
Please message me to let me know what you need for it and form of payment.
Thanks.
Old 03-31-2026, 11:50 PM
60sstuff's Avatar
1966 with 093 head.
1967 with 670 head.
ID:	667376   Click image for larger version
The Following 2 Users Say Thank You to 60sstuff For This Useful Post:
Old 04-04-2026, 12:51 PM
“So that it may be properly torqued .” If all the other bolts with conventional heads can be properly torqued, why wouldn’t a conventional head bolt work in this location also? To quote Tom Vaught on these forums “Engineers do stuff for a reason.” but I can’t figure out what their reason is in this case.
Terry Hunt
Old 04-04-2026, 01:35 PM
If you look at the photo of the 66 head the seat where the bolt head mates to the cyl head looks to be recessed. Thinking maybe the hex of a regular bolt would not work or you would not have much engagement with a socket. The special bolt moves the hex up to where a socket can grab it. Dont know why the head was machined that way. Also it looks like the protrusion for the AIR passage would interfere with a standard bolt head.
The Following 2 Users Say Thank You to TXSTARFIRE For This Useful Post:
Old 04-04-2026, 03:36 PM
60sstuff's Avatar
EXACTLY ^^^^
It’s pretty obvious when looking at those two cylinder heads in post #8.
