Old 04-07-2026, 08:59 PM
thirtypointer's Avatar
thirtypointer thirtypointer is offline
Default Anti Hop Bar install on a BOP ten bolt?
I plan on adding a set of Edelbrock no hop bars to my 65 which is equipped with a 10 bolt BOP rear end. When I tested fitment with the factory upper control arm still in place, it appears the Edelbrock anti-hot bar will not work with the BOP without quite a bit of modification? In the attached picture, the blue arrow points to where I believe the anti-hop bar is designed to fit around a fin on the differential, which does not lineup with what I have.
Have any of you installed the anti-hot bars on a similar rear end?
Thanks,
Dan
1970 Tempest (428 Whitmore, Cliff Q-jet, Doug Nash Five Speed) slowly coming back to life
1965 Lemans (462 Butler, Cliff Q-Jet, Muncie M20 with 3.55s)
Old 04-08-2026, 04:34 AM
Have you up graded to poly control arm bushings yet?
I know you have those bars, but I would do the bushings first.
Old 04-08-2026, 04:38 AM
Bad idea in the rear arms - will bind them up.
Is there a threaded hole on the bottom finger of the bracket? It may be the one to use to clamp to the web.
Old 04-08-2026, 04:44 AM
Not when there lubed as they should be.
Old 04-08-2026, 05:18 AM
3X24SPD 3X24SPD is offline
I have never used the Edelbrock version- but I have installed 3 sets of the Genuine Suspension & Lakewood versions on 65-66 GTOs.
To install them on a 10 bolt, there is a bit of grinding (but only on the LS bar) that will be necessary to clear the housing rib. You can see why on the 3rd pic attached.
ID:	667871   Click image for larger version
ID:	667872   Click image for larger version
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
Old 04-08-2026, 08:09 AM
Thanks. That’s what I wanted to hear! I just did not want to get too deep into it just in case it. Mine look similar to yours. Did you notice any change in traction with the three installs
Old 04-08-2026, 01:17 PM
I use the Eddys on mine, and I put the Lakewood version on Dad's car.
Both do the same thing.
Yes it has made 60 foot times more consistent and the cars more predictable. They work great for drag radial applications where you want separation.
Over time I took them a step further with adjustable upper bars and double adjustable shocks so I could fine tune things. As I added more power I found I needed more rebound control to slow the separation down.
https://youtu.be/XqEydRRRwqE
Old 04-08-2026, 02:27 PM
67drake's Avatar
67drake 67drake is offline
FWIW, I did use the Edelbrock no hops on an 8.5 years back. I remember I had the same concern, as they didn’t really fit out of the box. I had to do some grinding on the rear end housing and no hops to get them to fit.
‘55 Catalina
Old 04-08-2026, 07:46 PM
AG's Avatar
AG AG is offline
You can't test fit it with the upper control arm on and the bushing in the rear. You need to unbolt the upper control arm and remove the bushing in the rear.
Old 04-08-2026, 08:44 PM
ANDYA ANDYA is offline
I just went through this recently with a 12 bolt rear out of a 65 Chevelle that’s going into my 65 GTO. After doing some research I went with the TA Performance no hop bars. They are very nicely made out of 3/4” thick steel with nice welds. Just like every other brand I had to do some grinding on the rear and also on the bars. The idea is to grind strategically to remove as little material as possible. When I was done the bars looked like they came that way and what I did to the rear was unnoticeable.
The Following User Says Thank You to ANDYA For This Useful Post:
Old 04-09-2026, 08:37 PM
Thanks Drake!
Old 04-09-2026, 08:39 PM
True. Just getting a looksie before diving in. Have you installed any?
Old 04-09-2026, 08:52 PM
SRGN SRGN is offline
I'd be more worried about dead hooking with a stock-ish 8.2 10 bolt. The 8.5 10 bolt out of a 71-72 Skylark is considerably stronger. Ran one in my old bracket car for a few seasons without issue, high 1.6 60' times. If it was faster I would have done axles, but I didn't have any issues with the stock 28 spline stuff. My GN also had an 8.5, 60' in the 1.4s but I did axles in that car. Both cars ran boxed lowers with poly bushings, stock upper arms.
The Following User Says Thank You to SRGN For This Useful Post:
Old 04-10-2026, 05:40 AM
I use wagon rear coil springs in all my 65-66 GTOs.
This drastically changes the rear suspension geometry- and makes a car even more susceptible to wheel hop.
The No-Hop bars, as can be construed from the name- cure that.
I also use Hotchkiss Upper & Lower Trailing Arms & Sway Bars.
Here's a good thread you can read on the subject:
https://www.v8buick.com/index.php?th...p-bars.395276/
The Following User Says Thank You to 3X24SPD For This Useful Post:
Old 04-10-2026, 10:31 AM
AG's Avatar
AG AG is offline
Yes, I've installed them on a couple of 12-bolts and two 10-bolts. I've had to machine some of them to fit properly. First set was from HO Racing and they fit well. In my experience, they completely eliminated wheel hop and work very well.
The Following User Says Thank You to AG For This Useful Post:
Old 04-12-2026, 06:02 PM
Thanks everyone for the advice and pictures. We were able to get the anti-hot bars installed today. My experience was the same as what you all reported as thry required some fabricating and such. The old bushings of course were there to get out. Can’t wait to get it to the track to try it out. The control arms definitely sit a lot higher!
ID:	668091   Click image for larger version
Old 04-12-2026, 08:41 PM
AG's Avatar
AG AG is offline
Check and adjust your pinion angle as necessary now. You will be glad you installed these.
