Old 04-13-2026, 03:40 PM
mysticmissle's Avatar
Default 1968 gto long block YS
March build automatic, looks
Clean under the sheet metal but rings and valves are stuck.
16 heads, no intake but I think I have a 68 kicking around if it helps. Rear valley pan bolt boss has been tapped for 3/8 16" should be able to be helicoiled to 5/16
This has Been Sitting under a bench for 20+ needs rebuild
As seen $1100 Norwalk delivery available with pre payment
ID:	668137   Click image for larger version
ID:	668138   Click image for larger version
ID:	668139   Click image for larger version
ID:	668140   Click image for larger version
Old 05-26-2026, 08:11 AM
Sold locally thank you for opportunity
