Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 04-14-2026, 09:41 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Default 403 Guys ! New pair Gen 3 OLDSMOBILE Edelbrock RPM Heads 61029
I have a brand new pair of Gen 3 Edelbrock Performer RPM aluminum 61029
For Oldsmobile V8
These have the fuel pump clearance and the heart shape fast burn chambers 218 cc intake 77 cc chamber flat tappet hyd cam springs 400 425 455 403 Stroker BBO SBO Text Larry 214-399-5841
heads for sale local deals no shipping willing to drive some for meet up.
North Texas East Texas Central Dallas Ft Worth Ennis Corsicana Waxahachie Waco Tyler Athens Canton Fairfield Texas
$2100 cash that is $400 below retail MSRP
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 04-20-2026, 12:04 PM
Bump
Name:	Screenshot 2026-04-20 105339.jpg
ID:	668524   Click image for larger version
Name:	Screenshot 2026-04-20 105236.jpg
Old 05-01-2026, 01:06 PM
No one here building up their 403 ? I just got one so I may use them but they are still for sale 403 - 425 - 455 Olds these have a 2.15 intake valve so need a larger bore like 4-12-4-15 minimum
Old 05-21-2026, 02:38 PM
I traded a 12 year shotgun I had for a very clean low miles rebuilt 403 , really nice deal. I will probably run these heads and the RPM intake I have and use cam and headers from the 350 Cutlass wagon and see how it goes ! https://youtube.com/shorts/uxP9qKjuE...PkAvI1vbpnKr-b
Old 05-22-2026, 07:30 AM
P@blo's Avatar
P@blo P@blo is offline
Nice 66 Larry! I'd say you did well on the shotgun trade. Best of luck to you.
The Following User Says Thank You to P@blo For This Useful Post:
Old 06-05-2026, 02:52 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Heads
Hope that 403 has a built bottom end. Those E heads with make a stock bottom end 403 relieve itself out of the side of the block. Ask me how I know. Should be run on a 455 only with a built bottom end.
Just my experience with the Olds I have run in the past.
I live in Ellis county also. what part are you in?
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
The Following User Says Thank You to skunkwerks For This Useful Post:
Old 06-10-2026, 02:39 PM
I am in the SE bottom S of Alma the 403 will be kept in its safe RPM range, re-use the mild 214/224 112 cam that's in the 350 currently should peak at 5300 RPM and not mill heads just do .027" 4.40" bore Cometic head gaskets and raise the 403 from 7.9 to 8.5:1 83 cc to 77cc re-sue the headers and port match my RPM intake to BBO gasket. Not a high dollar or max effort thing just play and see what a true bolt one top end can do on a smog existing short block in nice shape. The #'s 350 would then be out and eventually be a stroker 428 CID flat top, decked short block with a built bottom end & roller cam Take my wagon that's 4370# 3.08 gear 350 cruiser that runs 15.0's on 93 octane to a 13 second 87 octane setup then fix the A/C
