Old 04-15-2026, 11:42 AM
Cammer-6 Cammer-6 is offline
Default re-anodizing aluminum trim recomendations please
my 67 Sport Coupe trim is getting tired
Looking for a reputable place to strip,polish recoat
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-18-2026, 07:09 PM
gtospieg gtospieg is offline
Why not just strip it yourself and then periodically polish it. It's been working for me for years.
The Following User Says Thank You to gtospieg For This Useful Post:
Old 04-19-2026, 12:34 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Is there some non-mechanical way to strip anodizing away?
Old 04-19-2026, 06:34 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Anodize can be stripped off with Easy-off oven cleaner.
Old 04-19-2026, 09:07 AM
what polish do you use? any swirls show up?
Ive thought about doing that and using Cerakote
Old 04-19-2026, 12:53 PM
400 4spd.'s Avatar
https://mcnicholsanodizing.com/
Very good quality, but long wait times when I used them several years ago.
Old 04-19-2026, 05:14 PM
thanks for that
so what process do you do today?
Old 04-19-2026, 08:00 PM
I have to look in the trunk and see what polish I'm using....but no swirls. I do try not to touch the aluminum and that certainly helps extend polish intervals.
Old 04-20-2026, 05:00 AM
Jeff Hamlin's Avatar
When I had the Beltline moldings refurbished on the '66 back in the 90s They had removed all the anodizing, repaired, polished, and then applied a clear coat.
The clear started lifting within a few years, so I polished it all off.
Since then all I do is use Wadding Polish.
I too have been doing this for years and the moldings still look great.
ID:	668508   Click image for larger version
ID:	668509   Click image for larger version
Name:	G.T.O.S. CLUB DECAL xx.jpg
Old 04-20-2026, 02:22 PM
On the post cars the vertical piece of trim for the rear window post has a metal clip in the trim. I couldn't see a way to remove that clip that wasn't going to be destructive to the trim. I decided at that point it would be easier to just polish it all.
Old 04-20-2026, 04:13 PM
I hadnt thought about removal of those clips,good advise
Old 04-20-2026, 07:01 PM
I missed the clips too and when I brought my trim to the place to have everything reanodized they noticed the clips. They said if they had gone ahead with the clips in place it would have ruined their equipment. Thus the decision to take everything home and polish it all myself. Saved money but definitely didn't save time....I spent about 70 hrs picking and filing and straightening(this doesn't include removing the entire interior to get at all of the trim). Then 80 grit(on the worst parts) all the way to 2500 then polishing after not being able to get the pieces anodized. In the end well worth it.
Old 04-20-2026, 10:19 PM
Thanks guys. I had considered this approach but didn't know if it would work.
