Old 05-06-2026, 09:02 PM
Shiny Shiny is offline
Default Paint for Emblem?
What white paint and color have you used for an emblem like this?
I have some model car enamel.. anything better? How white of a white?
I spent a half hour with a dremel and some polish and it cleaned up great. No pitting!
Old 05-07-2026, 09:27 AM
Cammer-6 Cammer-6 is offline
was it white or black?
I agree,model paint
sometimes a qtip will work if you dont have a proper trim brush.
When almost cured a thumbnail will clean up what was outside the lines
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 05-07-2026, 12:37 PM
Terry M. Hunt Terry M. Hunt is offline
Default Paint for emblem
One Shot sign painters enamel. Used by pin stripers for many years.
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
The Following User Says Thank You to Terry M. Hunt For This Useful Post:
Old 05-08-2026, 10:53 PM
tempest1964's Avatar
I watched a video on YouTube of a guy painting some emblems. He thinned his paint down and used a syringe to spread it out. Believe he said the needle was a #20. By thinning the paint and using the needle, it flowed everywhere it needed to go.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
The Following 4 Users Say Thank You to tempest1964 For This Useful Post:
Old 05-09-2026, 01:34 PM
pfilean's Avatar
pfilean pfilean is offline
I have used the duplicolor tube with the brush included. same stuff I use to touch up little chips on the other parts of the car.. As suggested the little excursions outside the lines come off easily later. Unless you remember your first grade teacher telling you to color inside the lines.
The Following User Says Thank You to pfilean For This Useful Post:
Old 05-09-2026, 03:46 PM
Thanks all
Here's one of the YouTube videos using a dispenser needle. I like the concept but I suspect the results will vary with the paint.
Link to YouTube Emblem Painting
The One Shot paint looks great, just expensive for one or two emblems.
I don't know if the Testors model car paint will hold up on a car so I'll look at the Dupli-Color (or similar) touch-up at the parts store. If not too expensive, I'm leaning that direction vs the model car enamel.
Mike
Old 05-09-2026, 10:28 PM
GT182's Avatar
GT182 GT182 is offline
A good gloss enamel white paint. Try model paint, but there's got to be something much better and thicker Something that levels out and won't show any brush marks.
If you use model paint, let it dry for a week or so and put a good clear coat over it to protect it.
But Dupli-color sounds better. Make sure it's thinned out so it runs a bit and is smoother
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
The Following User Says Thank You to GT182 For This Useful Post:
Old 05-09-2026, 10:59 PM
Held for Ransom's Avatar
I wonder if a paint pen would work...
So long, farewell.
Old 05-09-2026, 11:03 PM
I think I'm going to try this Rustoleum oil-based enamel. It is cheap but sold for use on metal outdoors. I expect it will hold up better to UV, water, and temp cycling better than Testors but let me know if it's a bad idea. Hopefully it has a high solids and won't need thinning.
Old 05-09-2026, 11:06 PM
Good idea. Probably would be fine... I'm just foolish or frugal, flip a coin. The auto touch-up pens are almost $20 and I like the idea of dispensing with a needle and letting it flow out.
Old 05-10-2026, 09:08 AM
All Ive ever used is model paint
that said I did try thinning out.
It was OK at first but then developed cracks.
Unthinned is still ok 40 yrs later
Old 05-10-2026, 10:51 AM
Good to know the model paint holds up, thanks! Definitely the lowest cost option I'm aware of and I probably have some white. I'll also get the Rustoleum just because and compare the two before committing.
BTW, took a chance and ordered these from Amazon... I was surprised how well the point held up. They worked great to clean and polish where nothing else reached:
Name:	Screenshot 2026-05-10 084259.jpg
Old 05-10-2026, 03:41 PM
another tip that may have enhanced my application is the oven.
when you smell the paint,turn oven off.
never let paint get over 150*
Old 05-17-2026, 05:10 PM
I did not have white model paint so went with the Rustoleum.
I dispensed with a syringe, tried unsuccessfully to just fill the cavities and not over-run onto the faces of the outlines.
I ruined it once by trying to polish before it had hardened and had to strip it. Doh!
I let it skin over for a few hours, then wiped the excess off the borders by soaking a piece of cardboard in thinner and using it like sanding board. Worked well, left some smears as expected.
Here's where I am. Plan is to let it dry for a week before hitting with the polish again. This stuff dries and cures SLOW. Hopefully the scratches and smears will buff out. Some light pitting, but not much for a 56 year-old part that lived a hard life.
I'll compare with a repro I have but pretty sure this will win just because.
Mike
ID:	670237   Click image for larger version
Old 05-18-2026, 06:19 AM
Jeff Hamlin's Avatar
Thumbs up The Rustoleum is a good choice.
I did the top of my Van with it just over two years ago and it takes a beating and has held up great.
Name:	NOR 2025 1.jpg
Old 05-18-2026, 11:07 AM
do the slow and low bake instead of waiting a week
even a heat lamp will work
Old 05-18-2026, 12:15 PM
Thanks, good to know it holds up! That was one of my questions.
Thanks! I tried to educate myself on this and decided it's not worth the risk of having to strip it again if I overheat it. By filling the cavity, the film thickness is very high which is less than ideal.
The adhesion won't be great to begin with. I couldn't practically roughen the cavities and didn't use a primer so using this paint is probably sketchy.
If there was a 2K gloss white epoxy paint, it would probably be a better match for this application... but I didn't think about that before I understood how long this alkyd paint takes to cure.
I'm in no hurry, will just keep it in a warm place for a week or two.
Learn as I go, then forget it and learn again....
Old 06-03-2026, 05:39 PM
After sitting for 2 weeks, I pulled the emblem off the shelf and polished the haze off. The paint did not lift nor wrinkle.
I like the color and gloss.
But if I do this again, I will look for a 2K epoxy-based paint to avoid the long dry time.
Here's a photo with an unfinished survivor behind it. The Rustoleum restored part looks flashy by comparison but good enough.
I found it interesting that the original was missing paint on the horizontal leg of the "A". If I was guessing, a mask was used to paint these, probably sprayed.
As you can tell, the original paint thinned out near the edges and did not flow up the "sides" of the letter "walls". This means I "overfilled" mine but hey, I bought a small can of this Rustoleum!
Mike
ID:	671296   Click image for larger version
Name:	Missing Paint on Original.jpg
Old 06-03-2026, 07:37 PM
they do make a hardner for Rustoleum
Can get it on Amazon or Tractor supply
Old 06-05-2026, 01:12 PM
Rachelsdad's Avatar
Quick points:
I had a pinstriper do the white outline on the rear quarter emblems (gold anodized aluminum) on my '63 Bonneville, after I tried unsuccessfully to mask, prime with self-etching stuff, and spray color (spray touch-up, matched to '63 Pontiac Ivory).
He used enamel which he only thinned enough to coat evenly without brush marks. After that, I use a good spray wax (Meguire's) after each wash, and only lightly buff to remove excess wax from the gold.
Now, for my 8-lug center caps, I used Eastwood Chassis Black (satin), with matching primer, applied with a foam dauber. This coating is very thin, and excess wipes off easily with a rag or shop towel. However, it's easy when the lettering is pretty much the width of the dauber edge. I do the same thing with the spray wax on the center caps.
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
POCI #3596 (since 1978)
The Following User Says Thank You to Rachelsdad For This Useful Post:
