Old 09-02-2025, 11:41 AM
grivera's Avatar
grivera grivera is offline
Default Aluminum Head Nipple Restrictor Mod?
It's been mentioned here several times that a restrictor should be inserted in the hose from the passenger side head to the heater core, particularly when using aluminum heads as the nipple screwed into the head does not have a restriction. Sometime ago, I saw a post showing a pipe plug screwed into the threaded end nipple. I'm curious what was done to accommodate a pipe plug as a 1/4" is too small in diameter and a 3/8" is too large?
Pic of the type of nipple that goes in the aluminum:
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 09-03-2025, 09:42 AM
78w72 78w72 is offline
Cant comment on the barbed fitting, but another way to restrict the coolant flow to the heater core is to use a thick stainless steel washer placed right at the heater core inlet, I did that on my aluminum head engine 10+ years ago and it seems to be working fine, no problems with the heater core... but I have also read & seen where nothing was used to restrict the flow and no problems with blown out heater cores.
Old 09-03-2025, 10:42 AM
JLMounce JLMounce is offline
I have not used a restrictor on my KRE headed engine for 10 years and have not had any issues. Original heater core to the car as well.
-Jason
1969 Pontiac Firebird
The Following 2 Users Say Thank You to JLMounce For This Useful Post:
Old 09-03-2025, 11:12 AM
indymanjoe's Avatar
I didnt want to chance it so i put a small rubber hose inside the heater core hose. seems to work fine with the 15yr old heater core. E-heads fwiw
I am the Thread Killer!
The Following User Says Thank You to indymanjoe For This Useful Post:
Old 09-03-2025, 11:39 AM
grivera's Avatar
Thanks all - some good Ideas! To me the small effort is worth it. Not doing the mod and not having issues is only anecdotal evidence, and I suppose the same for those who have done the mod and haven't had issues - but certainly a cheap price to pay.
indimanjoe - that's pretty slick - is it like a 1/2" hose you used?
Will Rivera
Old 09-03-2025, 01:09 PM
If you look at the original heater core (if you still have it) the inlet is restricted so another restriction would not be needed. The tube of the heater core is bent inward in about 4 places at the very end where the hose goes on.
Old 09-03-2025, 01:35 PM
grivera's Avatar
Yep - I've seen that on my 69's heater core- apparently the factory wanted a restriction. Unfortunately, the replacement core has a round opening.
Will Rivera
Old 09-03-2025, 02:12 PM
indymanjoe's Avatar
LOL i wish i could say what size it was. it was in my box of hoses etc.. it was a tight fit but so far no issues. roughly 3k miles this summer and no issues.
Old 09-03-2025, 08:52 PM
Since your hole size is somewhere between fitting a 1/4 or 3/8 pipe tap find a regular straight thread tap and thread it for a non-hardened set screw. Loctite the set screw in place then drill a 1/4” hole through it.
It’s not like you need to seal it so a pipe plug isn’t necessary.
Old 11-03-2025, 09:46 AM
chrisp chrisp is offline
Just crimp the tip of the brass core inlet tube
Old 11-03-2025, 04:32 PM
If you are using a brass fitting just solder the hole closed and drill a new hole any size you like.
Old 11-13-2025, 12:23 PM
tempest1964's Avatar
I used this on my new build with KRE heads. Ounce of prevention:
https://jagsthatrun.com/products/hea...=6291689799723
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 12-14-2025, 06:36 PM
lust4speed's Avatar
I'm late to the party again. Originally installed the restrictor from the bottom, but now installing them from the top.
Name:	Heater nipple.jpg
ID:	662180   Click image for larger version
Name:	Heater nipple restriction 1.jpg
Mick Batson
The Following 3 Users Say Thank You to lust4speed For This Useful Post:
Old 12-15-2025, 12:35 PM
imposter's Avatar
imposter imposter is offline
where did you get that setup
Old 12-22-2025, 02:49 AM
lust4speed's Avatar
The nipples came with the heads and the inserts were whatever I could find in my brass fittings bucket. The second pic insert started out as a pipe plug and I drilled a 1/4" hole through it and chamfered the hole.
Mick Batson
Old 12-22-2025, 07:08 PM
jerry455 jerry455 is offline
It seems a lot of us did the same thing with drilling an insert in the brass fitting for the Edelbrock head. Mine was drilled a 1/4" also.
Old 05-12-2026, 05:51 PM
73ta's Avatar
73ta 73ta is offline
Edelbrock heads, replacement heater core, ac pullies, high flow water pump. Worked for 25 years, no restrictor, no issues.
The Following 3 Users Say Thank You to 73ta For This Useful Post:
Old 05-13-2026, 04:03 PM
65 Lamnas's Avatar
If you have an older (or original) heater core, you'll see that the end of the 5/8" hose nipple is "crimped" which acts as a restrictor. New heater cores haven't had this feature for many years. You should probably run a restrictor with a new heater core. A piece of 5/8" OD teflon round stock with a 1/4" hole worked for me.
