Old 05-22-2026, 04:03 PM
Bill Eveland's Avatar
Default Caught some air over the weekend
For the guys who havn't seen this on fb. I dropped a few hundred lbs with fiberglass front end and wilwood brakes. Hooked up good on this launch. Car didn't like a harder hit , left at 3k off the brake.
ID:	670743   Click image for larger version
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following 8 Users Say Thank You to Bill Eveland For This Useful Post:
Old 05-22-2026, 04:49 PM
steve25 steve25 is online now
Thumbs up to ya!
Why no wheely bars?
Old 05-22-2026, 05:12 PM
PAUL K's Avatar
PAUL K PAUL K is offline
That's about as good as it gets ��
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
First time, thats why. Im going to drop the ladder bars down to lower hole and tie the front end down. Wheelie bars are still an option. So this doesn't happen again. I want want to carry a 2ft wheelie out. Just not on the back bumper again.
Thumbs up to ya!
Why no wheely bars?
6.27@107
9.97@131
Old 05-22-2026, 08:11 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Holly Crap!
You must be making Big power!
Old 05-23-2026, 02:45 AM
Dragncar Dragncar is offline
What are you running for a engine these days ?
Old 05-23-2026, 07:44 AM
517 Ia2, Edl wideport heads
6.27@107
9.97@131
Old 05-23-2026, 10:22 AM
tooski tooski is offline
WOW!
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 05-23-2026, 12:22 PM
Shiny Shiny is offline
As a spectator, that's incredible!
I would be clenching everything if I was inside.
I assume you are flying blind...how do you actually manage this?
Old 05-23-2026, 03:29 PM
Well hopefully its going straight , all i could do was stare at the hood scoop and I did peddle the throttle some so didnt come crashing down hard. no major damage but did take it to work and did an alignment on the car, adjusting the ladder bars to get the rear end square. I set it up for a 4 wheel so can see the rear toe in.
6.27@107
9.97@131
The Following 2 Users Say Thank You to Bill Eveland For This Useful Post:
Old 05-23-2026, 07:24 PM
scott70's Avatar
scott70 scott70 is offline
Some air is putting it mildly!
Old 05-23-2026, 10:24 PM
sdbob sdbob is offline
Glad every thing is ok, no bends or' brakes'. Nice wheel stand.
Old 05-23-2026, 10:52 PM
SRGN SRGN is offline
Travel limiters on the front will help, as well as the ladder bar adjustment. When I did that years ago, it went right after going on the bumper and I had to get out of it so it didn't go into the wall. Cracked the trans case and bent the subframe when it came down.
Old 06-09-2026, 04:51 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
V1.......Rotate!!
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 06-09-2026, 07:57 PM
The little that I've read ladder bars are simple but you lift high or lose traction. There was an article in an old Car Craft that Larry Tores and Gary Boze talked about advantages and disadvantages of ladder bars and 4 links. Explaining how to design them.
Old 06-10-2026, 07:30 AM
Talking
Further what was nice about that article that made understanding links very simple. They used cardboard! The chassis was one piece,very simple cutout, the rear end was another piece, then the links, one ladder bar, one set of unequal length 4 links, and one set of equal length 4 links. Regular pins were used for pivots. This cardboard is one dimensional. You held the chassis in 2 fingers of one hand. Then you took your 2 fingers of your other hand and torqued
the rear end with the different links. For me a person who knew nothing sure made it simple to understand what the and how the links worked affecting the chassis. I made the parts out of very thick sturdy cardboard still have them somewhere. Just my 2 cts
Old 06-10-2026, 09:10 AM
johnta1 johnta1 is online now
Saw Bill's Pontiac and the Gassers at Coles County Dragway last Saturday. Good turnout I believe.
Car looked good!
Old 06-11-2026, 11:45 AM
Thanks John! Couldn't get it to hook for nothing though. But we still had fun with the Gasser Shootout...
6.27@107
9.97@131
Old 06-11-2026, 02:42 PM
Ladder bars adjusted down to bottom hole, was in the middle and resent pinion angle. Viking DA front shocks on the way...
6.27@107
9.97@131
Old 06-26-2026, 05:13 PM
77 TRASHCAN's Avatar
Wow, glad you made a clean run
Just as long as we don't see you on one of those "Walked away" videos........
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
