Old 05-23-2026, 09:39 PM
Default Surface rust removal on machined spindle surfaces?
I'm helping a buddy with getting his 1970 Catalina back on-the-road.
It's been sitting for over a year with the front brakes shoes and hardware replaced, but the wheel hubs and bearing not put back on. He was looking for a replacement hub, which he recently found.
He made the mistake of cleaning off all the grease on the spindles and now they've got surface rust all over them. A fairly decent amount.
What is the best way to get the rust off? I've heard vinegar works, but haven't ever tried that.
Is there something stronger to spray on or brush on and let it do the work?
Or do I just get out the 800 grit and machine oil and polish everything?
Thanks in advance!
Old 05-23-2026, 11:00 PM
tempest1964's Avatar
tempest1964 tempest1964 is online now
Evapo-Rust works well for me. Phosfo spray is supposed to be good as well, although I’ve never used it.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 05-23-2026, 11:06 PM
BB70's Avatar
BB70 BB70 is offline
You could try some evaporust, soak a rag and wrap around the spindle, then a plastic bag over the rag. Or the 800 grit like you said.
Old 05-24-2026, 01:04 AM
Fine stainless steel wire brush, the size of a large toothbrush. The kind you use in a weld shop to brush TIG welds while they’re still hot
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 05-24-2026, 06:41 AM
Lemon juice on a soaked rag for overnight.
Old 05-24-2026, 06:50 AM
steve25 steve25 is online now
Get a brass wire wheel to load in your drill .
Old 05-24-2026, 07:26 AM
Elarson's Avatar
Elarson Elarson is online now
800-1200 grit wet-or-dry sandpaper and WD-40 has worked good for me.
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 05-24-2026, 08:41 AM
Like I posted just remove the rust that you can with a brass wire wheel as it’s only the bearing inner races that SIT on the spindle not the bearing rollers .
the races don’t roll on the spindle.
Remove the rust you can and grease it all back up and slap it together.
Ware protective glasses when wire wheeling.
Old 05-24-2026, 09:27 AM
I found fine sandpaper clots up too easily.
3M 7440 work nicely and "wraps" around spindles quite well.
The Following 2 Users Say Thank You to Scarebird For This Useful Post:
Old 05-24-2026, 01:38 PM
zippy's Avatar
zippy zippy is offline
Scotchbrite pad as above, brown and WD40!!! Or 0000 Steel Wool and WD40 That also works well for getting rust of chrome bumpers. Steel wool is actually less agressive than the scotch brite
Dan Pesonen
"If it ain't broke, modify somethin till it is"
The Following User Says Thank You to zippy For This Useful Post:
Old 05-24-2026, 07:20 PM
Nobuddy Nobuddy is offline
The grey ultra fine scotchbrite works well for me. Always keep some next to the sink for cleaning up stuff without marking steel. It will put a fine buff polish on aluminum. I think it is rated at about 3000 grit.
The Following User Says Thank You to Nobuddy For This Useful Post:
