Old 06-02-2026, 05:34 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Car Show Continued: A few Third Gen cars were there as well, with one in full "Kit" makeup. A couple of early GTOs showed too. All in all, a good group in about 150 cars that were there. June 6th is the big one in downtown Arlington, TX.
ID:	671248   Click image for larger version
ID:	671249   Click image for larger version
ID:	671250   Click image for larger version
ID:	671251   Click image for larger version
The Following 6 Users Say Thank You to srmmmm For This Useful Post:
  #1962
Old 06-03-2026, 04:49 AM
3X24SPD 3X24SPD is offline
Default 6 2's
Well, if three 2 barrels are good (TriPower), then six should be outstanding, right?
This is a real Pontiac "Six-Pack".
Wieand Drag Star.
For those in the know- it's a 1955-60 intake.
Rather than modify it for late model heads- it's going on top of a 1959 389.
Won't be the first time I've built a whole new car around a set of carburetors.
(then replaced the carburetors).
Not sure what the body style the engine will go into just yet. TBD.
An early coupe, no hood. And some body lines & tail lights that appeal to me.
That's all I have for a concept so far.
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI Weiand Dragstar with 6 Strombergs
4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
The Following 8 Users Say Thank You to 3X24SPD For This Useful Post:
  #1963
Old 06-03-2026, 05:21 AM
Default BugCatcher
Fabricated some prototype actuation linkage for the Bug Catcher, and a throttle return.
Works great.
The mockup 3D Printed Bracket will be replaced by 4" 6061 Angle as soon as I get done machining it- and the temporary 12" 1/4" steel rod will be replaced with SS & Heims.
The temporary Weber 4" 5mm Heim linkage will also be replaced with 1/4" SS & Heims as well, soon as those parts arrive.
Replaced the 3D Printed Bellcrank yesterday- with one from Ron's FI that arrived yesterday.
4-Speed
The Following 9 Users Say Thank You to 3X24SPD For This Useful Post:
  #1964
Old 06-03-2026, 12:16 PM
Verdoro 68's Avatar
Replaced the repro 1/4 panel GTO decals with a set of NOS decals. Big difference in the weight and crispness of the letters! NOS on the bottom.
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 8 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1965
Old 06-04-2026, 09:43 AM
73_Lemans_350's Avatar
73_Lemans_350 73_Lemans_350 is offline
Drove it to a local cruise night. Beautiful weather for checking out some classics!
Design Engineer | Dakota Digital
1973 Lemans - 350, Centerline Auto Drags and Cooper Cobras
The Following 8 Users Say Thank You to 73_Lemans_350 For This Useful Post:
  #1966
Old 06-04-2026, 03:07 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Monday I used our survivor 59k mile now 60K mile 66 Star Chief Executive sedan to kick off the Pole Barn Garage Poverty Tour 2026 to cruise Route 66 and did first Day 1 of a week long torture test but went back home for work. It was flawless just hot for me not the car it was fine and drove around 900 miles in a day and a half . Didn't even use any oil ! https://www.youtube.com/watch?v=N1xlCtKnzP4&t=305s
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
The Following 8 Users Say Thank You to PONTIAC LARRY For This Useful Post:
  #1967
Old 06-04-2026, 05:39 PM
Verdoro 68's Avatar
I've been watching the Poverty Tour - looks like a lot of fun. Last year Dalton ran the Poverty Tour to Arizona for Duct Tape. It's cool to see it grow into it's own thing. It's getting me excited to get the Javelin on the road.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #1968
Old 06-08-2026, 12:04 PM
Verdoro 68's Avatar
Spent Saturday reinstalling a freshened up headliner in the Ventura then cleaning up and doing a health check on the GTO. I ordered headliner material for the Ventura from SMS about a year and a half ago...still MIA . I busted out the Krylon Satin Italian Olive again. Sounds like a bad idea, but it actually looks pretty decent if you later it on in thin coats.
GTO is doing well, everything under the valve covers looks like the way I left it. I have been chasing a drooping passenger side headlight door which is driving me nuts. Adjusted the spring tension, arm to door position, replaced a check valve, 1/2 the vacuum lines, a vacuum actuator and the headlight switch and it still sags when the car is off. This is new since it got back from the body shop. I have no idea what could have happened but it's annoying. Got it working well enough to attend a show on Sunday with Cole.
ID:	671458   Click image for larger version
ID:	671459   Click image for larger version
ID:	671460   Click image for larger version
ID:	671461   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 5 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1969
Old 06-08-2026, 08:50 PM
carcrazy carcrazy is offline
Started bleeding the brakes on my 67 GTO. Car has been sitting for several years now so I used a pressure bleeder and found multiple leaks. Fixed all but one.....at the front distribution block which will require removal of the booster, master cyl. to get to. Ugh.
The Following 3 Users Say Thank You to carcrazy For This Useful Post:
  #1970
Old 06-09-2026, 01:46 AM
jhein's Avatar
jhein jhein is offline
Your son is very fortunate to have a dad like you. Salute.
The Following 2 Users Say Thank You to jhein For This Useful Post:
  #1971
Old 06-11-2026, 11:37 PM
tempest1964's Avatar
Finished fabricating my one off throttle cable for my dual quad setup. Required cutting, fitting and creating a new end with solder. Ended up being about 6” shorter that when I bought it in order to fit my dual quad setup.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
The Following 6 Users Say Thank You to tempest1964 For This Useful Post:
  #1972
Old 06-12-2026, 01:31 PM
And here it is installed. You can see how the bracket is moved rearward. Still tried to go for a stock type look.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
The Following 8 Users Say Thank You to tempest1964 For This Useful Post:
  #1973
Old 06-12-2026, 02:00 PM
tom s tom s is offline
Covered the 63 Lemans after 4 week ends of car shows,put it on the lift and lowered the 62 GP for a AM show in the morning.Nice not having to work on them.Tom
The Following 6 Users Say Thank You to tom s For This Useful Post:
  #1974
Old 06-12-2026, 05:59 PM
67drake's Avatar
67drake 67drake is offline
FINALLY got the ‘55 Catalina out of upholstery jail today! It was done a few weeks ago, but between my schedule and all the rain we’ve had, this was the first chance I’ve had to run down to Illinois to get it picked up.
Hope the link works. I took a short video.
https://m.youtube.com/watch?v=-8AYLyQUmyU
ID:	671660   Click image for larger version
ID:	671661   Click image for larger version
‘55 Catalina
The Following 10 Users Say Thank You to 67drake For This Useful Post:
  #1975
Old 06-12-2026, 09:50 PM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Super interior!!!
The Following User Says Thank You to Jack Gifford For This Useful Post:
  #1976
Old 06-12-2026, 10:13 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Wow, really nice!
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
The Following User Says Thank You to Skidmark For This Useful Post:
  #1977
Old 06-12-2026, 10:16 PM
Gary Logan's Avatar
Gary Logan Gary Logan is offline
Formerly GnXRanch
It was trim day on the 2+2. Cleaned two different colors of paint off of some ebay beltline moldings and buffed them out. Had fun getting to all of the backsides of the clips to get nuts on them. Stripped, painted, and installed the rear seat fill panels to match the original Blue Charcoal. re-stretched the headliner and put the A-pillar and windshield trim in.
Next is the sail panels and rear window moldings. I looked at what it will take to replace some rear seat bottom springs, but the frame is too far gone.
ID:	671672   Click image for larger version
ID:	671673   Click image for larger version
65 Catalina 2+2, 455, 6x-8, 2802, 4-spd
65 Catalina 4dr Hardtop, 389 4v, Auto
The Following 5 Users Say Thank You to Gary Logan For This Useful Post:
  #1978
Old 06-13-2026, 05:52 PM
67drake's Avatar
Nice day for a change here in SW Wisconsin. I was itching to drive so I took the ‘55 and my son took his ‘71 to grab a bite to eat in a town about 25 miles away.
Called my engine guy today too. Dropping my 400 off next weekend for him to deal with and assemble. My wife wants me to get the ‘63 running again so she can have her own car to run around in. Yeah, I have kinda been dragging my feet on that one.
ID:	671690   Click image for larger version
‘55 Catalina
The Following 4 Users Say Thank You to 67drake For This Useful Post:
  #1979
Old 06-13-2026, 06:13 PM
sdbob sdbob is offline
Went to buddies logging operation on Youngstown Ridge near Latrobe. Reason he told me Friday he has a Ford 750 .I got the hood scoop for my 63 Lemans. I cut the truck hood all around the scoop now bolts are soaking in penetrate. It looks just needs sanded grille is with it. I had force $20.00 on him. We go back maybe 40 years.Working at his home, his sisters,bought a lot of rough cut lumber from him. I have dome rough cut pine stored in garage ,it is not warped.
The Following 3 Users Say Thank You to sdbob For This Useful Post:
  #1980
Old 06-13-2026, 08:28 PM
WQ59B WQ59B is offline
Bled the brakes on my '64 and slapped the new rubber on.
Next: replace broken accel linkage and get ready to drop the 389 back in.
The Following 3 Users Say Thank You to WQ59B For This Useful Post:
