Old 06-13-2026, 03:08 AM
John Langer's Avatar
John Langer John Langer is offline
Default Norwalk 2026
I’ll grudge race anyone $1000 minimum only stips, pro tree. Small tire. Na.
The Following 4 Users Say Thank You to John Langer For This Useful Post:
Old 06-13-2026, 09:47 AM
Gary H's Avatar
Gary H Gary H is offline
I can't compete, but I'd love to see someone step up, Pontiac or otherwise. You have one bad bird! Seen it run many times
The Following User Says Thank You to Gary H For This Useful Post:
Old 06-18-2026, 11:27 AM
Mike Davis's Avatar
If someone steps up I'll throw some money in the pot to the Winner.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 06-20-2026, 11:05 AM
PAUL K's Avatar
PAUL K PAUL K is offline
It'd probably be better of to throw in a few bucks for the runner up.
Go fast, see Elvis!
The Following 4 Users Say Thank You to PAUL K For This Useful Post:
Old 06-21-2026, 10:15 AM
Region Warrior's Avatar
O my god...
Member you 20 yrs ago checking valve springs between next round.
Then changed converters.
Old 06-22-2026, 02:05 AM
Dragncar Dragncar is offline
Engines like that change valve springs every few passes. 1" + lift and 8500 RPM. Moving bore spacing around. Offset valve guides. Honda rod journals ect. Billet everything. Too high a dollar game for 99.99% of us. Still glad people do though.
High HP NA Pontiacs are flat out cool.
Old 06-23-2026, 02:38 PM
1.080” lift, 9k rpm. Crank has way too much stroke for Honda rod journals.
Old 06-26-2026, 06:25 PM
wreckmastr's Avatar
We'll come have a beer with you.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 06-29-2026, 04:49 PM
Ill say it.
Where's the Canucks?
Old 06-29-2026, 04:55 PM
Good luck getting a beer down faster then John.
Make that 3 in 10 minutes!
If still needs refreshers.
Old 06-30-2026, 11:28 PM
Ha JL.
Where's all brags from east coast mafia?
Guy with 68 FB claimed be fastest small tire pontiac 2'yrs ago.
I'd put up a case of Sam Adam's and bottle of buffalo trace bourbon.
