Old 06-21-2026, 08:17 PM
vertbird's Avatar
vertbird vertbird is offline
Default 76 TA nose repair
Guys, I have a few cracks in the nose of my 76TA. I'm not even sure exactly what material I'm dealing with, but what is the best way to fix these areas?
Old 06-25-2026, 03:04 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default fiberglass
Originally Posted by vertbird View Post
Attachment 672234
Should be blow molded fiberglass.
Sand a V grove in the crack only. Then clean with acetone or rubbing alcohol.
Mix resin and brush into V grove. Then add some fine hairs of glass mat and push
down into V. Let dry and sand and primer with 2K.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 06-25-2026, 03:15 PM
73ta's Avatar
73ta 73ta is offline
Use SEM #68422 flexible bumper repair
Old 06-25-2026, 03:17 PM
73ta's Avatar
All of the above except fiberglass. Use SEM Flexible bumper repair #68422
Old 06-29-2026, 09:51 AM
skunkwerks's Avatar
Default To each his own
SEM 68422 is better suited for 70-73 flexible bumpers on Firebird /TA's.
I would not use it on Hard molded fiberglass as it will not reinforce the fiberglass cracked area and the crack will propagate as all fiberglass will do with cracks if not addressed correctly.
To each his own. Repaired many a Vette and I know because I had this same issue.
