Old 07-08-2026, 06:07 PM
JLMounce JLMounce is offline
Default Fast Monty Shroud
There's been a lot of cooling discussions here about shrouds, fans, radiators etc.
I decided recently I wanted to try one of Mike's shrouds after I started having some cooling issues with my previous setup.
That previous setup was a Cold Case CHC11 radiator with a Flex-a-Lite Black Magic 180 fan. This was all in front of a 580hp 465.
Full context, I did end up replacing the radiator with this change, so I can't give everything a 100% apples to apples comparison. My original CHC11 sprung two small leaks from the upper portion of the end tanks. Likely because I accidentally smacked the core with the engine when I was installing it last. I had cured that leak with a few Bars stop leak tablets, but ever since I did that, the system wouldn't cool as efficiently.
I finally hit 225 degrees in stop and go traffic in 90 degree weather and that was my impetuous to get this changed.
So what did I do? Basically, everything.
New CHC11 radiator from Cold Case
Fast Monty's dual 14" fan shroud
Dual Maradyne M142 fans
Big 3 wiring upgrade
Robert Shaw 180 degree stat
New AC Delco Upper and Lower hoses
New heater core hoses
My car with the previous setup has always run 195 on the highway, and would run about 205 in slow moving main street style cruising. In true stop and go traffic, or idling, it would slowly creep to 210 before leveling off.
With this new setup, also in 90+ degree heat, the engine now runs on the stat on the highway. In that slow moving main street cruise type situation, I observed nearly 15 degree cooling reduction, with the system running right at 190.
The idle creep is still there, but dramatically slowed. It now takes roughly 15 minutes of loaded idle time (in drive, on the brakes) to reach 210 degrees. If the car is put in park, it slows that time down even further. If the hood is opened, the fans pull the temps down to below fan off threshold of 183 degrees.
So, what is this telling me? By and large this radiator/fan/shroud combination is doing everything it's supposed to be doing. The hood open behavior leads me to believe I have a heat soak issue related to air under the hood. When the car is moving, even a little, the hot air is being evacuated. When stopped, it's building under the hood and finding place in front of the radiator to move, causing a loss of cooling efficiency.
Through a bit of research, it's also possible my water pump may be partly to blame. I am running a PRW aluminum performance pump with the 6" AC pulley. This pump is somewhat designed for higher rpm use and may give up some flow at idle and low engine speeds. It's designed to shine above 3500 rpm for sustained periods.
For my car that spends most of it's life cruising around, the Flowkooler may have been a better choice as it's designed around providing better low speed coolant flow.
I'm testing some additional idle RPM to see if that has any effect. I may look at other remediation measures such as hood vents as well.
Anyhow, I'm pretty stoked on this setup. The install looks nice as well compared to the old Flex-a-Lite fan which always kind of looked like an afterthought.
-Jason
1969 Pontiac Firebird
Old 07-08-2026, 07:27 PM
AG's Avatar
AG AG is offline
I also use a PRW ali water pump with a stock 3 core radiator and a flex fan in my '72 Lemans. The car has a hard time getting to 180F in 90+ weather highway or idling. I don't think it is stagnant air that is the cause of your issue. In my race car, I use a generic ali radiator with a Mark VIII E fan ans a Meziere E water pump. Runs 180, gets to 200 at the end of the track and is back to 180 in the pits.
Old 07-08-2026, 09:18 PM
Mine is actually the opposite. I haven't been able to hot-rod this engine enough to make the temperature rise.
It used to be the slower and lower RPM I drove at, the warmer it would run.
I added 50 idle rpm and that seemed to have actually helped a bit.
-Jason
Old 07-08-2026, 11:48 PM
RocktimusPryme's Avatar
Assuming the stock core dimensions are roughly the same as the Cold Case numbers, Lemans radiator probably has about 30% more frontal cooling surface area compared to the 1st gen Fbody. That solves a lot of problems.
My Fairlane race car as a 503 ci engine with a cheap ebay special 1" thick core radiator for a like 84 F250. But its got a huge front surface. It keeps the BBF cool even with two 12" fans just ziptied to it with no shroud.
My 67 on the other hand has been a battle, and it has the same nice Cold Case radiator the OP mentioned. You are just limited to a somewhat small radiator in those.
FWIW I also think I have my cooling solved with the junkyard PWM fan swap I did. Big 18" single PWM out of a volvo XC90. Its been in for over a year and I dont think Ive seen a number that starts with a 2 since. I have to admit that your setup is way prettier though
Mine mostly sits right at the 180* thermostat, but once in a while it will creep up to like 185-187 with seemingly no difference in inputs.....that irritates me. I dont like not knowing why something is happening.
Old 07-09-2026, 09:45 AM
Frontal area is a large consideration. There's a reason the 2nd gen F-body went to an A-Body sized radiator. The brunt of the cooling efficiency happens in the first core of the radiator, so the larger you make the front face, the more cooling you receive. The extra water capacity is helping quite a bit as well.
-Jason
Old 07-09-2026, 09:49 AM
AG's Avatar
AG AG is offline
This seems like a low speed air flow issue, what is the cfm rating for your fan? The Mark VIII is supposedly 4400 cfm.
Old 07-09-2026, 11:23 AM
Each fan is rated by Maradyne at 2135cfm. As tested by mike in a controlled manner, loaded with a radiator in front, they pull about 1500cfm each. I'm unsure what the loaded cfm of a mark 8 fan is. But it's likely comparable to my current fans in total cfm.
I'll have the car out for a bit in 100 degree temps this weekend. So far, that small rpm bump at idle does seem to have helped. I'm never leaving the car idling anywhere for 15+ minutes anyway, so it's somewhat of a non-issue. Just transparent about what this setup is and is not doing.
-Jason
Old 07-09-2026, 10:46 PM
AG's Avatar
AG AG is offline
Thanks for the info, very helpful.
Old 07-10-2026, 10:46 AM
65madgoat's Avatar
The Mark VIII is not 4,400. Maybe 3,200 on its absolute best best day, if that, I believe others have shown.
Hope FMG will test a 1990s Mark VIII fan as there are repops of it for $85 on RockAuto that should suffice for a test.
Old 07-10-2026, 10:57 AM
Could be the difference between unloaded and loaded testing. As FMG has pointed out thoroughly is that many people test these things inaccurately by just placing an anemometer right up against the fan where you can get big turbulent spikes in airflow.
-Jason
Old 07-10-2026, 11:27 AM
AG's Avatar
AG AG is offline
Whether it's 3200 or 4400 cfm it works so I'm happy.
The Following User Says Thank You to AG For This Useful Post:
Old 07-10-2026, 12:36 PM
65madgoat's Avatar
I still run the FoMoCo (cough cough) Mark VIII fan too on a car... but I see a new current GM 19" version electric fan that is what nearly every custom builder is putting on their radiators lately. Hopefully Mike can test that one as well....
Old 07-10-2026, 01:13 PM
Fastmonty's Avatar
Fastmonty Fastmonty is offline
Love the write up... and yes, I'd love to test the supposed monster CFM Mark VIII... can someone get me a part number? please email me FastMontysGarage at gmail. Thanks all!
Old 07-10-2026, 01:20 PM
Pretty sure that's the C7Z06 fan. I believe it's a 600 watt brushless fan. That's some pretty serious wattage.
The price was just too much at close to $500.00 per fan, but the FMG shroud does also fit this bad boy. https://www.spal.com/it/-/30107107-v...320p-r-a-n-94a
1000 watts in dual configuration. In Mike's testing he saw loaded CFM per fan at or above 2000cfm.
-Jason
Old 07-10-2026, 01:43 PM
65madgoat's Avatar
Sorry I was wrong -- it is this Vintage Air fan 850W assembly most high end builders are using not a GM unit:
https://vintageair.com/additional-op...s-and-shrouds/
Old 07-10-2026, 01:47 PM
65madgoat's Avatar
[QUOTE=JLMounce;6623488]Pretty sure that's the C7Z06 fan. I believe it's a 600 watt brushless fan. That's some pretty serious wattage.
This sure is worthy for your 1969:
https://vintageair.com/monster-1967-...hless-fan-kit/
Old 07-10-2026, 02:02 PM
That's a big ass fan.
-Jason
Old 07-10-2026, 02:23 PM
Thats pretty close to what the Volvo fan I swapped in is. Its often called a 19, but really its more like 18.5.
https://www.240turbo.com/BrushlessFans.html
There is a ton of good information in this link, including the Vintage Air fan listed. They also have the XC90 Bosch fan I used, which is available in all kinds of things. I have the same fan in a shroud for like a 2005 Mercedes SL500. This is where I started when I put together my swap. Of course I have a terminator X which made my life easier on the controller side.
If I was going to pay the aftermarket price for a big PWM single fan, I think its hard to beat the DeltaPAG package because it comes with the brushless controller.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 07-10-2026, 10:59 PM
Yeah, my setup since it's triggered by a FiTech 30001 is on/off. You can of course wire the brushless deals to behave that way, but you miss out on the whole PWM thing for ramping in voltage on an as needed basis.
It's always going to be better for the engine, performance and efficiency to be able to keep a constant temperature vs swings up and down like an on/off system will create.
-Jason
Old 07-12-2026, 11:26 PM
Formulabruce's Avatar
While all the "Mods" are interesting, and fast monty has some ideas as a auto plumber, a New pattern COPPER Cold Case will cool better than aluminum.
Also the 421 Mod will eliminate the need for electric fans..... fact..
The aftermarket has won the marketing battle with Plastic and aluminum, and bigger alternators, and bigger wires.... That said...
" Long may we DRIVE !"
